weird cel code
Old May 29, 2012 | 11:17 PM
3easy21's Avatar
Default weird cel code
I'm getting multiple CELs, they appear randomly. Itll be off for a day then come out of nowhere, and then go away for some time.
The codes are:
3 Map Sensor
7 Throttle Angle
14 Electronic Air Control
Bad Map sensor? whats throttle angle and electronic air control mean?
Old May 29, 2012 | 11:28 PM
Swap'DShuttle's Avatar
Default Re: weird cel code
Throttle position sensor. Other one sounds like your electronic idle control motor?
Could have a fault in the ecu? Try a buddies for starts.
Old May 30, 2012 | 12:08 AM
3easy21's Avatar
sucks having non vtec buddies lol, Ill try calibrating the tps today since i never did that.
Old May 30, 2012 | 12:26 AM
If its a stock throttlebody you shouldnt have to. Should be fine.
You can check first to make sure using an ohm meter. Can't remember specs off the top of my head but they are easy to find on google.
Non vtec ecu will work fine to see if there is a problem with yours as long as its the same gen. Just will throw a code for vtec.
Old May 30, 2012 | 01:26 AM
HondaPartsHero's Avatar
Technical Hero
Post your year/make/model/engine/mods?
shabam
Oct 23, 2006 08:31 AM
boostmywankle
11
Apr 19, 2005 04:41 PM
WickedWerx
Oct 28, 2004 07:02 PM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
IVI
Aug 26, 2004 01:04 PM
