lean on deceleration normal?
Old May 26, 2012 | 10:18 AM
3easy21's Avatar
Default lean on deceleration normal?
I just got a aem wideband and i noticed that when i left off the gas it goes 15+ to not registering when i let off above 3,000rpm. Is that normal? Idles around 13.5 and 12.1 WOT.
Old May 26, 2012 | 10:28 AM
mark@silbernage's Avatar
Default Re: lean on deceleration normal?
From what I've seen, that's normal - perhaps even desirable. As long as you don't go so lean as to misfire and make the transition back to idle (or cruise) smoothly you're fine.
I use a WB02 sensor also - and since MAP values are used to calculate injector open times.. you can pretty accurately manage AFR during deceleration.
What are you using for engine management?
Mark
Old May 26, 2012 | 10:50 AM
3easy21's Avatar
Right now just a Chipped P28 with a basemap.
Alot of times when i left off the gas i get loud pops
Old May 26, 2012 | 11:15 AM
Prob. too lean then - it won't hurt things, well, I suppose it could swell the muffler a bit if it got bad enough... ; ' )
If you can, it would be better to tune it a bit and try to keep the AFR in 15-17 range when you're in full-on deceleration.
You MAP is probably between -10 to -14 PSIg decelerating; I shoot for about 15.5:1 there and it seems to work pretty well.
Mark
Old May 26, 2012 | 01:45 PM
cagedGSR's Avatar
Lean is how a.motor deaccells. You'll always flatline when you let off, if you don't, you're too rich. Your idle is a bit rich, wot is good.
FWIW, I idle 14.3-15.8, wot is 11.8-12.2. I know my car is rich.
Old May 27, 2012 | 06:26 AM
Brian_TII's Avatar
Virtually all fuel injected cars go completely lean on decell. It actually cuts fuel completely. This is normal, safe, and desirable.
Old May 27, 2012 | 11:04 PM
3easy21's Avatar
ok good, for a moment i thought my engine was getting damaged
gnxpro24
Mar 17, 2012 02:25 PM
csmith21
Apr 28, 2010 10:08 PM
jdm95
Engine Management and Tuning
Feb 2, 2010 08:10 PM
accord99power
Nov 25, 2009 07:40 AM
93c1sol
Sep 8, 2005 11:06 AM
