Swap Questions...
Old 06-22-2012, 02:59 PM
nightscream's Avatar
Default Swap Questions...
Thinking about trading my EG for a 95 DB7 LS car... I get to keep my FULL 98 GSR swap. The 95 LS car will come with no motor, trans, or harness. If I've read correctly, I can use my 98 engine harness (plug & play) in the 95 LS but will have to run the vtec wiring to the shock tower harness??? Any additional info would be helpful!!!!
Old 06-22-2012, 04:02 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: Swap Questions...
Yes plug and play and add VTEC, knock and the IABS to the harness
Old 06-22-2012, 04:27 PM
Do I have to add these since I'm keeping it OBD1... especially since i have a Skunk2 intake manifold
Old 06-22-2012, 09:22 PM
dc_jdm_dreams's Avatar
If your using the 98 gsr harness and a gsr ecu with a obd 1 stepdown then you should not have to do anything unless I am not reading this correctly. Okay the car is a 95 with no engine/trans and you have a 98 gsr complete swap with the complete wire harness and ecu. then you should be able to pull the ls complete harness and run the gsr complete harness with a step down to run obd1 since thats what you want and everything will be fine. Someone feel free to correct me if I am wrong.
Old 06-23-2012, 01:47 AM
98 GSR motor, trans, engine harness with a chipped obd1 ecu...
Old 06-23-2012, 04:44 AM
Technical Hero
The LS cabin harness shouldn't have VTEC wired at the shock tower but here is an easy way to check:
As for the knock sensor I'm not sure where it's pinned at the shock tower but it probably won't be there either. What ECU are you running? If its a P28 ignore the knock and IAB wiring.
Old 06-23-2012, 10:34 AM
oh crap nice your awesome learn something every day thanks for the correction
Old 06-23-2012, 10:40 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Step-down? The 98 harness will plug into the 95 cabin harness at the shock tower and you can run obd1 ecu without any modifications. Vtec and knock sensor will have to be wired. I just put a 98 GSR swap into my 94 civic and used a skunk2 mani. If you already have a ecu chipped that bypasses the knock sensor you won't have to worry about wiring that up. if you look for the tech in hybrid for wiring a GSR swap into a vx civic it will show you where on shock tower plug it is
Old 06-23-2012, 10:49 AM
Global Moderator
Jimmy's Avatar
THE LORD OF CHAOS
06-28-2007 02:47 PM
Lucky-R
04-21-2005 08:27 PM
si foo
12-22-2004 11:00 AM
SOUNDEFFECTS
02-10-2003 05:08 PM
Quick Reply: Swap Questions...
