Compression Test results.
Old May 9, 2005 | 10:55 AM
bucdenny's Avatar
Default Compression Test results.
My car is smoking in high rpm. I thought it might be my rings. compression test results came out 170 across all 4. Is that stock? bad? too low?
Old May 9, 2005 | 11:09 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: Compression Test results. (bucdenny)
More info on the car is needed.
What yr/model/engine & how many miles.
Usually what you're looking for is even numbers across the board - which is what you have. Your compression test #'s may change over the years due to carbon build-up, so the fact that then numbers match indicate 'even wear' internally.
My '96 B18b1 (130k miles) read 205 across all 4 last time i tested it and my '92 B18a1 (140k) was around 190.
Old May 9, 2005 | 11:38 AM
adseguy's Avatar
Default Re: Compression Test results. (Tim2179)
in high rpms could be carbon build up, or in need of a valve adjustment, bnet a valve (usually get low compression as well, but not always). Those numbers are finr for your rings though
Old May 9, 2005 | 11:55 AM
riceball777's Avatar
if it smoking then i guess it burning oil right?
compression numbers dont mean anything when it comes to buring oil. thouse numbers are fine. my old b16 was 160 across all 4 cylinders. as long as they are all the same thats all that matters.
but if it smocking it could be either the oil rings or the valve guilds
Old May 9, 2005 | 11:56 AM
simon98h22's Avatar
Default Re: Compression Test results. (adseguy)
Get a leakdown test done.
Old May 9, 2005 | 04:12 PM
bucdenny's Avatar
95 gsr, 100000k on it. my cousin told me my wen my vtec kicks in and wen i shift to 2nd and 3rd, i get clouds of blue smoke! compression 170 all across all 4. i hope its not my rings.
Old May 9, 2005 | 04:30 PM
Dogginator's Avatar
Daisy... Daisy...
It could be leaky valve seals.
cryingsuns
Jul 28, 2013 10:21 AM
Blazeone
Feb 17, 2005 03:18 PM
Trellis
Sep 29, 2004 07:41 PM
EF8_SiR
Jul 20, 2003 10:24 PM
Andrew 825SM
Oct 19, 2002 10:05 PM
