PROBLEM! HELP PLZ!
Old Oct 17, 2005 | 11:25 AM
Projectdc2's Avatar
Default PROBLEM! HELP PLZ!
I have a 99 GSR and im tyring to install a new distributor rotor my stock one is stuck on there and wont come loose at all.. Any suggestions on how to break that ***** loose! Plz help!1
Old Oct 17, 2005 | 11:47 AM
MrAngry's Avatar
USE MAD VTAJK Y0!!11
sigh.
Old Oct 17, 2005 | 12:31 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (MrAngry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrAngry &raquo;</TD></TR><TR><TD CLASS="quote">USE MAD VTAJK Y0!!11
sigh.</TD></TR></TABLE>
Thank you for that extremely helpful information.
To the original poster, did you remember to remove the philips head screw in there? If so, what exactly is the problem? Is the screw stuck? Is it still stuck on without the screw?
Old Oct 17, 2005 | 12:34 PM
MrAngry's Avatar
Default Re: (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
To the original poster, did you remember to remove the philips head screw in there? If so, what exactly is the problem? Is the screw stuck? Is it still stuck on without the screw? </TD></TR></TABLE>
They'll never learn if you don't punish them!
Anyway, dub dee forty it.
Old Oct 17, 2005 | 12:43 PM
95lstegman's Avatar
BTW if you haven't tried it yet use a cordless drill w/ phillips head to remove it. corded ones are probably too powerful to control for this task and will likely strip the screw out. then you'll have to drill it out, and engines and engine parts like dizzies don't like metal shavings running around in them. just make sure it's a fairly small phillips head attatchment and that it's very pointy to get down to the bottom of the screw's hole.
Old Oct 17, 2005 | 01:55 PM
Projectdc2's Avatar
Okay well for sum odd reason my car runs hella weird... It does not want to start i checked air, Fuel, and spark its all there. Its nothing throwing a CEL light at all but i might think it is the TAP sensor thats on the manifold do you think thats the problem please help
Old Oct 17, 2005 | 02:05 PM
95lstegman's Avatar
Default Re: (Projectdc2)
TAP sensor?
130R
Welding / Fabrication
Jul 23, 2007 06:29 AM
burnitdown
Apr 17, 2007 10:15 PM
dcdcdc
Jul 2, 2006 10:18 AM
vizsual00
Mar 29, 2005 10:12 AM
wootcivic
34
Mar 22, 2004 04:01 PM
