phantom grip question
Old Oct 18, 2005 | 02:22 PM
gsr nate's Avatar
Default phantom grip question
im just about to order a new clutch/flywheel kit and i was wondering if the phantom grip is a good buy to go along with it, is it a true limited slip diff?
thanks for the help in advance, i already tried search
Old Oct 18, 2005 | 02:25 PM
98 Spec R's Avatar
Default Re: phantom grip question (gsr nate)
I would spend a little more and get an ITR diff. You can find them used for a good price.
Old Oct 18, 2005 | 02:53 PM
mjc1055's Avatar
Default Re: phantom grip question (98 Spec R)
If you already tried searching, then you didn't do a very good job. There are a lot of threads about how the phantom grip is junk, and pretty much anything else is better, at least regarding their non-extreme ones.
https://honda-tech.com/zerothread?id=1298062
https://honda-tech.com/zerothread?id=1128932
https://honda-tech.com/zerothread?id=1079970
Modified by mjc1055 at 4:08 PM 10/18/2005
Old Oct 18, 2005 | 03:27 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: phantom grip question (mjc1055)
Read the links that mjc1055 gave you. They are very good. Plus you can also search for "phantom" yourself here and find tons more.
To answer your question, no, it is not a true limited slip differential. It is basically two metal plates that spring outward to lock the spider gears. They don't do a very good job on turns, but in my opinion, for a very cheap LSD-like effect, it's not bad (IF, it is installed correctly).
You have to remember that the price of LSD's/Phantom Grips is just for the piece itself. You will have to install it yourself, or have it installed. If you're asking this type of question, I'm going to assume that you are not going to install it yourself. It's not going to be a cheap in labor, just to let you know. If you're going to be spending money, I'd go with a higher quality one.
OEM Honda, if you're not making huge power numbers. Or Quaiffe for anything else. Do a search for OBX's LSD. Lots of mixxed opinions, some saying it's just like Quaiffe, some saying it doesn't fit right, etc. Do some research.
American.Graffiti
12
Mar 24, 2009 06:29 PM
mh
Welding / Fabrication
Aug 1, 2006 09:19 PM
nickpirro
Jan 19, 2004 06:36 PM
RudeLude
Jan 3, 2004 01:47 PM
visual
Jun 17, 2002 05:41 PM
