Clutch related problem.
Clutch related problem.(part 2)
Part1
My gsr's cluth and flywheel where upgraded .(stage 2 , and 9 #flywheel)
it was properly broken in, and i install it .
every single bolt torqued down by the book .
the problem is that the clutch chatters.
specially in first. im not sure wich can cause this?
clutch master cylinder, or the slave cylinder?
Part2
ok ...so i bleed the system , and that didnt do it, i checked the clutch master , and that was the problem. (it had a nasty leak!) wtvr...
aright , so i finally replaced the CMC today , and after i intalled it , the clutch pedal :didn't have the same length .(now the travel of the pedal was like 1/2 inch shorter)... WTF???
adjusted the switch for the cruise control and bled the system.
and took it for a test drive, and the car didnt feel like it had that much torque now.
could it be possible that its sliping some?
it goes in & out of gear fine.
the clutch before fully engaged and disengaged within an inch after i steped on it
and now the clutch after i step on it for like 3/4 of an inch its when it stars to engage and disengage...
i drives ok and theres no sign of sliping when i step on the gas.
but i dont really kno if this is how it should be... or if it is ok for this to happen.
thanks!
Modified by ghostrider dc2 at 11:16 AM 11/5/2005
Modified by ghostrider dc2 at 11:19 AM 11/5/2005
Part2
thanks!
Re: (projectTeG)
yes .
i changed the throw out bearingsand they were properly greased.
and ill try bleeding the system 2morro!
thanks
but still dont have the exact answer if anyone knows...
thanks
Re: (ghostrider dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostrider dc2 »</TD></TR><TR><TD CLASS="quote">yes .
thanks
but still dont have the exact answer if anyone knows... </TD></TR></TABLE>
it might just be your clutch....certain clutches chatter at ya
thanks
Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">it might just be your clutch....certain clutches chatter at ya</TD></TR></TABLE>
i think it's just the non-full-faced discs that chatter. i don't think i've ever heard of a full-faced clutch disc that chatters.
Re: Clutch related problem. (ghostrider dc2)
eh........
ill just replace the clutch master cylinder first(wich is my best guess)
if it doesnt solve my problem .
ill replace the slave cylinder too
As has been stated, many performance (you said stage 2, which I would assume is a 6 puck style) clutches will chatter no matter what. If your pedal has decreased since installing a new m/c, you've probably still got air in the system. Try bleeding it some more. A hydraulic clutch setup should have next to no freeplay in the pedal, so if you have any freeplay, something's still not right.
Re: Clutch related problem. (nitrofish420)
when i installed the cmc the travel of the clutch decrease, (it just wouldnt go up any further even if i pulled it) so i just adjusted the bolt that connects the master and the pedal .
could it be the autozone MC?(wrong part)
and the clutch doesnt chatter no more
and theres no freeplay
but the travel its not the same. and I dont think it has the same torque.(maybe in my mind) ???
I think if that threaded rod out of the back of the M/C is adjusted OUT (toward the driver) too far, it may be holding the clutch slightly disengaged at all times. But I don't think there's very much adjustment on that rod, so that may not be the problem.
immalooser
04-14-2010 08:01 PM
badass civic
02-28-2009 05:32 PM
