Need help with idle problem!
Old Oct 18, 2005 | 08:05 PM
EF HATER's Avatar
Default Need help with idle problem!
The car is a 94 GSR with jdm type r motor, obd1-obd2 jumper, jdm type r ecu. I have this exact problem https://honda-tech.com/zerothread?id=1089291, I have replaced iacv, tried a gsr p72 and a chipped p28 all have the same results. I need some suggestions on what may be the cause. Oh, also i'm using the obd 1 gsr dist. and vtec solenoid, someone told me you can't use the gsr dist. on the r motor, but that makes no sence to me, is this true?
Old Oct 19, 2005 | 08:00 AM
EF HATER's Avatar
Default Re: Need help with idle problem! (jay88h)
bizzump
litoekneeil
Sep 22, 2010 08:05 AM
k_lude
Aug 23, 2006 01:10 AM
jdm4dr
Nov 23, 2005 12:39 PM
jdm4dr
Nov 21, 2005 04:55 PM
jdmef-9
Mar 28, 2005 02:04 AM
