Quick tranny question
Old Oct 17, 2005 | 10:45 AM
tegsp's Avatar
Default Quick tranny question
Is the b16 cable tranny the only one with 24 splines on the shaft that sticks out of the tranny? I need to know this before I go and drop a few bills on a clutch kit.
Old Oct 17, 2005 | 01:41 PM
95lstegman's Avatar
Default Re: Quick tranny question (tegsp)
off the top of my head i don't know, but if the seller is competent and a decent person they should be able to check for your to make sure of the number of splines and the shaft size for you. it doesn't take a genius to count the number of dimples in the hole in the clutch disc.
Old Oct 17, 2005 | 08:19 PM
tegsp's Avatar
Default Re: Quick tranny question (95lstegman)
The car that the seller took the tranny off of was a crx w/ a b18c1 in it. Will this si tranny bolt up to my 92 da with a 90-91 clutch kit?
Old Oct 17, 2005 | 08:55 PM
tegsp's Avatar
anyone?
Old Oct 18, 2005 | 04:42 AM
95lstegman's Avatar
well for starters, if the CRX it was in had a cable trans then maybe. if it was a whole GSR swap with hydro trans then there is no way it will work for you. it doesn't matter what engine it was used on as all b-series w/ flywheel (not flex-plate) are the same. what matters is the transmission it goes with. you need to ask the seller what transmission he used it on.
Old Oct 18, 2005 | 06:21 AM
tegsp's Avatar
It is definetly a cable tranny. I just need to know if the si cable tranny that worked in the crx would work in my car. He also said it had the same gear ratios as the type r.
Old Oct 18, 2005 | 07:02 AM
95lstegman's Avatar
well you need to know if he had the big spline or small spline cable transmission. just because it was in a CRX doesn't mean anything. CRX's didn't come with b-series transmissions in the first place, so you need to find out what transmission.
Old Oct 18, 2005 | 07:14 AM
tegsp's Avatar
Do you know by chance how big or small exactly the splines are?
Old Oct 18, 2005 | 08:08 AM
95lstegman's Avatar
i don't keep measurements but ask the seller if the clutch is for big splines or small splines. what year B16 trans is it? i thought it was all later YS1's had big splines, but B16's were all small splines. i could easily be wrong here. try searching on this issue.
Old Oct 18, 2005 | 01:49 PM
tegsp's Avatar
Im trying to find out which tranny this is by process of elimination. Now I just counted 24 splines on the shaft that sticks out of the tranny. According to what I have been reading, the early year crx/ civic have only 20 or 21 splines. Which trannys have a spline count of 24? Im pretty sure that all 92 and up cars have 26.
Old Oct 18, 2005 | 05:44 PM
tegsp's Avatar
bump for help
Old Oct 18, 2005 | 07:44 PM
tegsp's Avatar
can anyone help me out here?
Old Oct 19, 2005 | 08:12 AM
tegsp's Avatar
bump for a little help before class
Old Oct 19, 2005 | 08:08 PM
tegsp's Avatar
nobody knows?
Old Oct 20, 2005 | 12:20 AM
SlamminS85's Avatar
I HAVE YOUR ANSWER, just let me find this link
Old Oct 20, 2005 | 12:22 AM
SlamminS85's Avatar
Default Re: Quick tranny question (SlamminS85)
http://www.ff-squad.com/tech/temp/Bgears.htm
if you cant find your answer there, then i cant help you, and you can get a hydro tranny to work where a cable tranny used to be... its just hard as hell to do
Old Oct 20, 2005 | 05:06 AM
95lstegman's Avatar
are you sure '99-'00 Si has 4.266 FD? i have never seen any proof of this, nor have i heard/read anyone else corroborating it.
CapnKrunch
Nov 6, 2008 04:12 AM
marc-111
Jul 27, 2006 10:58 PM
Makdaddynuge
Dec 7, 2005 08:07 PM
TwoPointZero
Aug 12, 2004 06:34 PM
BseriesHatch
Nov 13, 2003 08:27 AM
