BRAKE light problem
Old Oct 17, 2005 | 10:30 AM
Spoogen_1's Avatar
Default BRAKE light problem
Specs: 98 Integra GS (Automatic)
**NOTE: I use to (before this problem) pull my E-brake up when parking.
Problem: Ive noticed in the past 2 weeks, every morning when I leave my house (Car is garaged), everytime I would take the E-brake off, the red BRAKE light on the cluster would stay on for about 2-3 minutes. BUT.... Everytime I would step on the brake it would turn back on for antoher 2-3 minutes. So in the course of driving and braking for lights or signs, it would like rest itself to stay on for another 2-3 minutes. This only happens in the morning. Afternoon and evening this doesnt happen. Does anyone know what can be causing this?
Old Oct 17, 2005 | 11:13 AM
98 Spec R's Avatar
Default Re: BRAKE light problem (Nexus131)
Check your fluid level.
Old Oct 17, 2005 | 11:15 AM
gsr dood's Avatar
yes.....the wire under the erake is loose from the butt connector same **** happened to me. take off the rear plastic center console (i think its like 4 screws) and jam that wire back into the butt connecter.
Old Oct 17, 2005 | 11:16 AM
gsr dood's Avatar
Default Re: BRAKE light problem (98 Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">Check your fluid level.</TD></TR></TABLE>
fluid may also cause it.
Old Oct 17, 2005 | 11:20 AM
blakezilla06's Avatar
Default Re: BRAKE light problem (gsr dood)
fluid lvl possibly...prolly the wire take off the center console about 6 to 8 screwes and there is a wire where the E-brake bar is take the wires and reconnect them to the main plugs! then baam it should be fixed perfectly!
Old Oct 17, 2005 | 11:33 AM
Spoogen_1's Avatar
Default Re: BRAKE light problem (1 fast dc2)
Ill try that, thanks
Old Oct 17, 2005 | 11:47 AM
Spoogen_1's Avatar
I tryed what you sed, and im going to continue to watch this during the week to see if it has stopped, if it hasnt ill check the brake fluid level
Old Oct 18, 2005 | 10:39 AM
gsr dood's Avatar
def let us kknow and checking the brake fluid takes 4 seconds open th cap and peek inside
Old Oct 18, 2005 | 11:45 AM
Spoogen_1's Avatar
Maybe you guys can help me out. Heres some pics.
The fluid level looks fine
Can you show me the right bolts to mess with
The sensor seems to be working im guessing.
I hate my e-brake now
Old Oct 18, 2005 | 01:58 PM
Spoogen_1's Avatar
bump
Old Oct 18, 2005 | 02:09 PM
cdntegintx's Avatar
That happened to me too, and there is a loose connection at the brake resovoir. If I wiggle the wires it will fix it.
Old Oct 18, 2005 | 02:17 PM
JDM-EJ1's Avatar
I would say the connector under the pedal.. But it looks fine.
You have tan interior, lol.
Old Oct 18, 2005 | 03:03 PM
Spoogen_1's Avatar
Default Re: BRAKE light problem (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
You have tan interior, lol.</TD></TR></TABLE>
yea cypruss green and gayfer automatic
Old Oct 18, 2005 | 03:04 PM
Spoogen_1's Avatar
Default Re: (cdntegintx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdntegintx &raquo;</TD></TR><TR><TD CLASS="quote">That happened to me too, and there is a loose connection at the brake resovoir. If I wiggle the wires it will fix it. </TD></TR></TABLE> Well i took off the cap to the fluid, do u think since the wire is connected that it helped solve the problem?
Old Oct 18, 2005 | 04:13 PM
hondab18b2001's Avatar
Default Re: (Nexus131)
Dude it's the fluid level..Just add a little fluid even if it seems full and you will see your problem is fixed...I also recommend you go to the dealer and get some honda brake fluid... they gave me a bottle for free Dont know about mixing fluids...
Mike
Old Oct 18, 2005 | 04:21 PM
...rohit's Avatar
Default Re: (hondab18b2001)
yes, i made the same post last week. i too have a 98 auto i just added a little more fluid(i had about the same amount as that pic) and it went away
Old Oct 18, 2005 | 04:28 PM
Spoogen_1's Avatar
Default Re: (desipiE)
I guess ill try that then and see. Ill keep you posted
Old Oct 18, 2005 | 05:52 PM
gsr dood's Avatar
def refill tha ****. even the littlest amount turns on the bake light.
Old Oct 18, 2005 | 06:00 PM
Spoogen_1's Avatar
Default Re: (gsr dood)
How come it only does it when the car is cold? Becuase when its hot the liquid expands and fills up the cylinder more?
&lt;---Suck at science
Old Oct 18, 2005 | 07:01 PM
...rohit's Avatar
i believe so. mine also only happend in the morning for about 5 min then it would turn off.
JDMguy88
Jun 21, 2008 08:58 AM
tennbidder
Acura TL, RL & ZDX
Jun 9, 2007 06:27 PM
low430
Oct 30, 2005 01:02 AM
hallec
Sep 21, 2004 12:44 PM
ace1875
12
Jan 17, 2003 06:55 PM
