Type R front end conversion?
Old Feb 18, 2006 | 10:24 AM
**DOHC HaTcH**'s Avatar
Default Type R front end conversion?
hey ive already searched for this and i cant seem to find wat im looking for. i also posted in cosmetics but didnt really get the response that i wanted.. so hears my question, i have a 97 gsr that i want to do a jdm front end conversion on. so ive been looking around and i was just wondering where would be the best place to purchase? i went to http://www.passwordjdm.com and that was a little too much. has any one else had any experience with purchasing this front end conversion. any info would be great
Old Feb 18, 2006 | 10:32 AM
.brian.'s Avatar
Default Re: Type R front end conversion? (**DOHC HaTcH**)
piece it together from the classifieds.
it is going to be expensive any way you slice it. don't forget to add in the cost of install if you can't do it yourself, plus paint.
here is a how-to for the install in case you ever need it
https://honda-tech.com/zerothread?id=1346217
Old Feb 18, 2006 | 10:49 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Type R front end conversion? (.brian.)
how much does the install usually run ? 1000 ?
Old Feb 18, 2006 | 11:09 AM
UCLA.lion's Avatar
I <3 My CB7.
Default Re: Type R front end conversion? (00IntegrAllmotoR)
my sister did a front end conversion, cost her 3900 w/ parts, paint matching, and man hours
*give them specific instructions to NOT paint the ducts in the bumper or else you'll be having to paint it black yourself.
*this was paint that chipped the first day she got it; so the quality of the paint might be cheap.
here's how it looked
Old Feb 18, 2006 | 11:10 AM
dumafu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">how much does the install usually run ? 1000 ?</TD></TR></TABLE>
Installation is free if you only use the top part of the jdm radiator where the headlights go... takes about 2 hours to align everything...after that, just screw the top part and the bottom of the "T" where the hood lock is together with some screws...
Old Feb 18, 2006 | 12:30 PM
hinds90's Avatar
Default Re: Type R front end conversion? (dumafu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumafu &raquo;</TD></TR><TR><TD CLASS="quote">
<U>Installation is free if you only use the top part of the jdm radiator where the headlights go</U>... takes about 2 hours to align everything...after that, just screw the top part and the bottom of the "T" where the hood lock is together with some screws...</TD></TR></TABLE>
Could you or anyone else explain this a little more ( the part that is under lined)
Old Feb 18, 2006 | 12:32 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Type R front end conversion? (hinds90)
I think they were implying that you can avoid having to weld in the JDM radiator support. I am just translating, not an expert.
Old Feb 18, 2006 | 12:36 PM
hinds90's Avatar
Default Re: Type R front end conversion? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I think they were implying that you can avoid having to weld in the JDM radiator support. I am just translating, not an expert.</TD></TR></TABLE>Do you know of anyone who has done it the way dumfa is talking about.
Old Feb 18, 2006 | 12:37 PM
jomama's Avatar
that's how i read it too... but i've never heard of anyone just SCREWING it together... i've always heard of welds... for the kit... check out password.jdm, ebay, etc., etc.... it's usually 1000-1500... depending on quality, parts, etc. it's expensive anyway you do it, like others have said
Old Feb 18, 2006 | 12:39 PM
Dogginator's Avatar
Daisy... Daisy...
No. I always thought that you had to drill the spot welds, remove the USDM radiator support, and weld in the full JDM radiator support.
Old Feb 18, 2006 | 12:59 PM
nathanong87's Avatar
i did the conversion by buying parts from extremedimensions. and used a USDM core.....wowser
my car
Old Feb 18, 2006 | 02:15 PM
dumafu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 &raquo;</TD></TR><TR><TD CLASS="quote">Do you know of anyone who has done it the way dumfa is talking about.</TD></TR></TABLE>
Heres the link to where i got the idea from...its not much, only saves you a few couple hundred bucks...if you look closely to the USDM and JDM radiator support, only the "T" is different, where the headlights go and where the hood closes...this site tells you to weld it, but i opted not too, instead, i just screw it securely in place...saves the money and time, plus by doing this your frontend is still in one piece...took me less than 3 hours...have fun...oh yeah, alignment is key, if your headlights don't fit properly push the "T" down more than srew it in place...
http://www.masetuning.com/jdmc....html
Old Feb 18, 2006 | 10:14 PM
SlammedDC2teg's Avatar
I got my front end from http://www.jdmteory.com for about 1400 and after paint and install , witch all came out great it cost me about $2600.
Old Feb 19, 2006 | 12:06 AM
I Kick Squirrels's Avatar
Default Re: Type R front end conversion? (SlammedDC2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">I got my front end from http://www.jdmteory.com for about 1400 and after paint and install , witch all came out great it cost me about $2600.
I got my JDM OEM HID front end conversion from jdmtheory.com about a month or two ago....everything came in great shape and great people to deal with
Old Feb 19, 2006 | 07:05 AM
teggsr925's Avatar
http://www.extremedimensions.com i know they hav it but its a knockoff
Old Feb 19, 2006 | 07:33 AM
justinsouza's Avatar
Default Re: Type R front end conversion? (teggsr925)
my roomate (turbo(less)Db8) got his from jdmtheroy.com and the headlights were perfect, it even came off an SiR-G db8 and he has a 98 db8 gsr. for jdmtheroy. he may have pics if anyones interested.
Old Feb 19, 2006 | 08:16 AM
Patron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggsr925 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.extremedimensions.com i know they hav it but its a knockoff</TD></TR></TABLE>
fiberglass
Old Feb 19, 2006 | 08:41 AM
veggiemaster's Avatar
Beautiful.
Old Feb 19, 2006 | 10:06 AM
.one lane's Avatar
.likes trains
Default Re: Type R front end conversion? (ikayto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikayto &raquo;</TD></TR><TR><TD CLASS="quote">my sister did a front end conversion, cost her 3900 w/ parts, paint matching, and man hours
Isn't that Trang's car?
Old Feb 19, 2006 | 10:11 AM
HT Black OPs
Default Re: Type R front end conversion? (Mr. One Lane)
i love seeing all these DB's with jdm fronts, so sexy
Old Feb 19, 2006 | 08:32 PM
For nickie at http://www.jdmtheory.com. He can even work out a price with you if you dont want certain things.
Old Feb 19, 2006 | 08:35 PM
Naruto's Avatar
Please please please for the love of all that is in the name of safety....WELD THE SUMBICH ON!!!!!
Old Feb 19, 2006 | 08:56 PM
hinds90's Avatar
Default Re: Type R front end conversion? (Naruto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">
Please please please for the love of all that is in the name of safety....WELD THE SUMBICH ON!!!!!</TD></TR></TABLE>
Is the link bumafu posted a safe way to do it and why wouldn't using bolts be as safe as welding just want to know.
Old Feb 19, 2006 | 09:02 PM
You would be a dumbass not to wled in you radiator support.
Old Feb 19, 2006 | 09:17 PM
hinds90's Avatar
ok I get that you need to weld it what I am trying to find out is if that masetuning link is a good idea were the guy just welded the top of the radiator support in not the whole thing.
Therumblingteg
Mar 2, 2003 07:52 PM
Tiwe
Aug 30, 2002 10:29 PM
Curious
Apr 10, 2002 04:43 PM
Curious
Apr 10, 2002 02:16 PM
