#1 and #4 dead HELP!!!
Old Feb 15, 2006 | 03:32 PM
b16crx88's Avatar
Default #1 and #4 dead HELP!!!
i got a ls vtec in my teg good compression on head and block and my #1,4 cylinder do not run. i have checked EVERYTHING that has to do with sparks and fuel. both spark plugs are not wet i switched injectors and thats not the problem. please tell me whats left. valve adj?
Old Feb 15, 2006 | 03:40 PM
PLAGUED_DB7's Avatar
Default Re: #1 and #4 dead HELP!!! (b16crx88)
Ecu??
Could have had a short and now its toast.
Old Feb 15, 2006 | 03:48 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: #1 and #4 dead HELP!!! (PLAGUED_DB7)
I agree. Its time to check the wiring.
Old Feb 15, 2006 | 04:35 PM
b16crx88's Avatar
check wiring where??? in the engine bay? i just did this swap so im not sure how it could fry the ecu. i have heard from a couple local people that the valves need to be adjusted and that they could be too tight. Now that seems logical other than the fact my car was just running fine on friday with my b20 vtec with this head...
Old Feb 15, 2006 | 04:39 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (b16crx88)
Why are the plugs not wet? Do you know if the injectors are firing? How is a valve adjustment going to alleviate injectors that are not firing? Check for pulses at the injector with a multimeter while the engine is running. You may need a valve adjustment, but from what you have said, I do not think that is the root of the problem.
sexyblack93lude's Avatar
see if all the injector plugs are plugged in tight
Old Feb 15, 2006 | 05:02 PM
b16crx88's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Why are the plugs not wet? Do you know if the injectors are firing? How is a valve adjustment going to alleviate injectors that are not firing? Check for pulses at the injector with a multimeter while the engine is running. You may need a valve adjustment, but from what you have said, I do not think that is the root of the problem.</TD></TR></TABLE>
checked for pulsing they do. i swapped injectors around and still 1,4 do not work. i had put like 10k miles on my b20 vtec. i am not turboing now so i pulled my engine and put a ls block in with the same gsr head back on. im stumped on why **** is not working. thanks for helpin though
Old Feb 15, 2006 | 05:17 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crx88 &raquo;</TD></TR><TR><TD CLASS="quote">
checked for pulsing they do. i swapped injectors around and still 1,4 do not work. i had put like 10k miles on my b20 vtec. i am not turboing now so i pulled my engine and put a ls block in with the same gsr head back on. im stumped on why **** is not working. thanks for helpin though </TD></TR></TABLE>
That is really strange that they are not injecting fuel. Does the fuel rail leak gasoline when you remove 1 and 4? I'm considering the possiblity that there is debris in the fuel rail blocking those injectors. (Yes, this is a long shot.)
Old Feb 15, 2006 | 05:46 PM
b16crx88's Avatar
my car was running fine before swap and when i did the swap i didnt take injectors or fuel rail off. i checked the filters anyway and still nothing..it is very frustrating
Old Feb 15, 2006 | 07:37 PM
b16crx88's Avatar
come on H-T
bodenman
Feb 26, 2014 02:15 PM
baonest
Dec 6, 2013 12:36 PM
phil_space
Sep 2, 2009 04:44 PM
crum
Oct 9, 2005 05:29 PM
integlude
Acura TL, RL & ZDX
Oct 3, 2004 04:33 AM
