Motor mount replacement
Old Feb 14, 2006 | 11:31 PM
dwn2earth922's Avatar
Default Motor mount replacement
Ordered some Hasport stock mounts (DCSTK) for my 94 LS. Wondering if anyone's seen any prior threads on replacing motor mounts? Also, what would be the proper way to support the motor while replacing? I'm told that you could support the engine with two jacks? Well, the mounts have been sitting for a month because I'm scared to lose a hand, but I'm tired of looking at them, so if anyone can shed any light on this. Thanks
Brian
Old Feb 15, 2006 | 06:07 AM
xtremegsr273's Avatar
my mounts r on the way and i'm taking the easy way out and letting a shop install them. the only thread i've seen so far on replacing the mounts was on team-integra and it was just the lower torque mounts. the best way to support the motor would probably be with a couple of jacks and a 2X4. thats what the article says anyways. if u r unsure, u might want to consider the shop. they r only charging me $75 to do it. takes the fun out of it, but i'll still have my hand. good luck.
Old Feb 15, 2006 | 08:03 AM
SilverDc2's Avatar
Default Re: (xtremegsr273)
their fairly easy to do,
when i replaced mine,
do 1 at a time, i have a jack w/wood under supporting it from the oilpan,
have another friend help you, jack up a bit unscrew remove and replace,
don't bolt them up 100% until you have all 3 main ones are in, align
Old Feb 15, 2006 | 08:54 AM
GSRVTEC1's Avatar
Default Re: (SilverDc2)
sorry for out of the subject but how much are them motor mounts? thinkin about replacing them on my ride
Old Feb 15, 2006 | 08:57 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Motor mount replacement (dwn2earth922)
If you're not sure about replacing the mounts,
Don't even bother with the rear firewall mount.
But the sides, all 4 in the front are Very easy,
Like Silver said, just a jack and piece of wood to keep from damaging the oilpan,
Do One at a time and it'll be easy as can be.
Old Feb 15, 2006 | 09:07 AM
97turboteg's Avatar
Default Re: (GSRVTEC1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">their fairly easy to do,
don't bolt them up 100% until you have all 3 main ones are in, align</TD></TR></TABLE> easy stuff
Old Feb 15, 2006 | 10:03 AM
hondafan62269's Avatar
The back mount is a pain. I recommend doing the rear mount first since you don't need a jack to hold up the motor and the stock mounts will let the motor sway a bit to get the bracket moved.
Old Feb 15, 2006 | 10:05 AM
SilverDc2's Avatar
Default Re: (hondafan62269)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafan62269 &raquo;</TD></TR><TR><TD CLASS="quote">The back mount is a pain. I recommend doing the rear mount first since you don't need a jack to hold up the motor and the stock mounts will let the motor sway a bit to get the bracket moved.</TD></TR></TABLE>
Very true, because if you do it after the motor is to stiff to have play.
Old Feb 15, 2006 | 10:22 AM
Spectrum24x's Avatar
I hate the back mount, i gave up on mine, its the only stock one =D
Old Feb 15, 2006 | 01:25 PM
Thanks everyone. To answer someones question, I think I paid 375, and they have different stiffnesses of poly available. I opted for the softest, but still better than stock. So 2x4 and jack, and do all mounts at the same time? I'm glad I asked, I was just going to do the driver side first since it looked the easiest.
Old Feb 15, 2006 | 01:29 PM
Don't do all the mounts at the same time. Start with the rear, then driver, then tranny. If you think about selling any of the mounts, i'm interested in the upper tranny mount.
Old Feb 17, 2006 | 03:31 AM
I'll take pics of the old mount when I get it out.
clem kevin
May 1, 2008 06:57 PM
steve96accord
Apr 5, 2006 12:03 AM
Rod.
Jul 2, 2005 11:49 PM
Bbasso
Mar 4, 2005 05:48 PM
ID_ten_T
Sep 19, 2004 12:26 PM
