Engine dry's out ??? WTF???
Old Feb 16, 2006 | 05:16 PM
00IntegraLSO-town's Avatar
Default Engine dry's out ??? WTF???
Alright i'm pretty good maintaining my LS. Do oil changes every 3 months and my car has no oil leaks anywhere. But when it comes time to change the oil there is hardly any there. Out of 4 qts there might be like 1 1/2 left. So what could this be. Oil filter is put on right and not to tight be tight enough. I'm tell you no leaks at all. I beat on it but not everyday, maybe every other SAT if that.
Old Feb 16, 2006 | 05:17 PM
DrakeMK3's Avatar
You're burning oil. When it burns, it disappears. Simple as that.
Also, you need to check your oil more often.
Old Feb 16, 2006 | 05:24 PM
blkb18's Avatar
Default Re: (DrakeMK3)
word to yo motha
Old Feb 16, 2006 | 06:32 PM
Am i burning because car is running to hot or just getting on the gears hard? I mean i got no smoke coming from my car and it only got 69,948 on it. Do my mods make it burn i,h,e or poor quality oil. I know I should probably be on synthetic but have made the turn over yet. Still waiting to get my 60,000 maintainance done.
Old Feb 16, 2006 | 06:53 PM
.one lane's Avatar
.likes trains
Think about it if you put 4 qt of new oil, and when you drain it out you only get 1 1/2 qt. Where did the other 2 1/2 qt go? You're either burning the oil or there's a leak. I mean seriously 2 1/2 qts can't just disappear on you, unless you're sometype of magician. When I had my leak it was coming out from my valve cover gasket.
Old Feb 16, 2006 | 07:04 PM
blkb18's Avatar
Default Re: (00IntegraLSO-town)
your burning because oil is pushing by your piston rings and/or valve seals, check your pcv valve, check your oil and add if low more often.
Old Feb 16, 2006 | 07:30 PM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: (blkb18)
you're gettin blowby... all your oil is goin out your exhaust pipe and into your intake mani...could be rings... burns more when u rev higher, too
X2BOARD
Oct 7, 2004 12:52 PM
mickey513
Feb 14, 2003 08:46 PM
94GsRacer
Sep 19, 2002 02:43 PM
PY2KITR1060
May 4, 2002 01:30 PM
tensai717
Dec 9, 2001 03:49 PM
