removing door panel
Old Feb 17, 2006 | 05:44 AM
96teggynonVtec's Avatar
Default removing door panel
how would u remove door panel on a 96 integra ls? seems like there is only 1 screw but i know there is more...
Old Feb 17, 2006 | 06:05 AM
djtsmith007's Avatar
Default Re: removing door panel (96teggynonVtec)
Take off the door handle cover, with one phillips screw driver..its hidden behind a little plastic door. Remove the cup on the arm rest with the same screwdriver. Take out the plastic screw thats at the front of the door. ( Remove the screw and pull out the plastic stopper) Starting from the bottom pull open the door planel from the mounting tabs. BE careful not to damage them, cause you wanna re-use them. And once the loswr half is undone pull up on the panel removing it from the window trim. Hope that helps!
Old Feb 17, 2006 | 06:17 AM
Iomega01's Avatar
Default Re: removing door panel (djtsmith007)
http://www.team-integra.net/se...D=591
Old Feb 17, 2006 | 10:08 AM
teggsr925's Avatar
in the little ashtray thing on the panel there is a screw and one up by the dash the panel will pop off after that usin a lil force
Old Feb 18, 2006 | 02:22 PM
Default Re: removing door panel (teggsr925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggsr925 &raquo;</TD></TR><TR><TD CLASS="quote">in the little ashtray thing on the panel there is a screw and one up by the dash the panel will pop off after that usin a lil force</TD></TR></TABLE>
Kinda missing some steps there man....
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
NtegraRacR05
Sep 15, 2003 06:57 PM
[HrZn]4life
Feb 11, 2003 01:21 PM
teg95
May 22, 2002 01:16 PM
onyx00
Sep 5, 2001 12:44 PM
