Rim bent slightly
Old Mar 11, 2006 | 06:24 AM
Baron55's Avatar
Default Rim bent slightly
I hit a the edge of a widewalk while turning and now my alightment is off, i think i need a control arm because the right front wheel is pushed back a bit and the rim(swirlies) is bent in a bit. bent enough for some of the coating to crack like its going to strip later.....not worried about the control arm, i will get it today, but is it ok to have the rim like that or would there be any effects?
Old Mar 11, 2006 | 11:03 AM
GorData's Avatar
Old Mar 11, 2006 | 01:03 PM
cm zak's Avatar
Unless its leaking air (use soapy water to check) then your rim will be fine, the seat of the tire and rim isnt probably messed up at all, it would take alot to damage that.
Fix your control arm, test the rim for leaks, but i wouldnt suggest doing any insane driving on it.
Old Mar 11, 2006 | 01:21 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Rim bent slightly (Baron55)
Is this just cosmetic damage or does the wheel wobble when rotating (runout)?
Old Mar 11, 2006 | 05:00 PM
Baron55's Avatar
got the control arm and the wheel wobbles, the rim is bent....cant be straightened right???? so looks like its time for some rims, but if i can get some swirlies or one, that would be nice...so any of you selling swirlies???????
Old Mar 12, 2006 | 05:00 AM
Baron55's Avatar
bump
Fliplm0de
Oct 15, 2006 08:56 PM
Tarlacon
Jul 12, 2005 02:36 AM
2ndGenREX
Mar 24, 2004 10:55 PM
CivicBoi
Jun 7, 2003 08:02 AM
1hotintegra
Nov 8, 2002 11:17 PM
