ignition timing / compression test
Old Mar 9, 2006 | 08:15 PM
panovel's Avatar
Default ignition timing / compression test
what is the best base ignition timing set to for 98 gsr mods: header, 2.5 catback exhaust , short ram.
what is good compression test lbs reading on internally stock 98gsr
Old Mar 9, 2006 | 09:11 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: ignition timing / compression test (panovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panovel &raquo;</TD></TR><TR><TD CLASS="quote">what is the best base ignition timing set to for 98 gsr mods: header, 2.5 catback exhaust , short ram.
what is good compression test lbs reading on internally stock 98gsr</TD></TR></TABLE>
stock ignition is 16 degrees, you can advance 2 degrees to 18
on the compression test, you dunt want less than 210 across the board
Old Mar 9, 2006 | 10:18 PM
RTI's Avatar
RTI
Default Re: ignition timing / compression test (JDM turbo DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC &raquo;</TD></TR><TR><TD CLASS="quote">stock ignition is 16 degrees, you can advance 2 degrees to 18
on the compression test, you dunt want less than 210 across the board</TD></TR></TABLE>
Isn't 210 a bit on the high side for a motor with stock compression?
Old Mar 9, 2006 | 10:48 PM
Default Re: ignition timing / compression test (RTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't 210 a bit on the high side for a motor with stock compression?</TD></TR></TABLE>
well i guess it does depend but ive had GSRs rebuilt with 210-220 across the board, anything less seems to be from valve seals or piston rings
Old Mar 10, 2006 | 08:31 PM
jdm_bones's Avatar
You want more than 185 on your compression bro!
Weapon X
Sep 8, 2006 01:20 PM
MestizoRacer310
Oct 24, 2003 10:17 PM
TurboJesse
Sep 23, 2003 06:20 PM
TurboJesse
10
Sep 16, 2003 05:06 PM
