how to remove outer door handle??
Old Mar 10, 2006 | 09:47 PM
cosmokramer's Avatar
Default how to remove outer door handle??
somebody help...i just spent 3 hrs switching everything over for the jdm door conversion but realized that my key will not work now. could anyone give some poiners for an easy way to remove the door handle? tutorial? anything....please. TIA
Old Mar 11, 2006 | 04:11 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: how to remove outer door handle?? (cosmokramer)
You pull the door liner, disconnect the lock rods from the handle, unplug the harness leading to the door handle, remove the 2 10 mm bolts, and remove the handle. The lock cylinders are easily swapped by removing a spring clip. I do not know if that can be performed with the handle mounted in the door.
Old Mar 11, 2006 | 08:19 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: how to remove outer door handle?? (Dogginator)
search topics "rear sedan door handle" or something like that, I did a DIY on how to do this.
Old Apr 7, 2006 | 11:39 AM
Default Re: how to remove outer door handle?? (00IntegrAllmotoR)
bump cuz i still havent finished this yet
Old Apr 8, 2006 | 10:43 AM
bump
Old Apr 8, 2006 | 11:07 AM
shamoo's Avatar
Will you make something up for me please?
You did an entire "JDM door conversion", but you can't figure out how to get the door handle off? Have you even removed the inner door panel and looked? It's very self explanatory.
If you want to remove the locking cylinder, you will need C-clip pliers, or steady hands and lots of patience.
Old Apr 9, 2006 | 09:55 PM
Default Re: how to remove outer door handle?? (shamoo)
yes, i did an entire jdm door conversion...of course i had to take off the panel and of course i looked. Have you done this before?? It is not self explanatory. I unscrewed the two bolts and unhooked the rod that unlocks the door, but i cannot get the rod off that "pops" the latch.
Old Apr 9, 2006 | 10:49 PM
Spectrum24x's Avatar
whats the difference in JDM doors? just lighter and less safe?
Old Apr 10, 2006 | 12:58 AM
no2unenolife's Avatar
no moldings thats the only thing i can think of
Old Apr 10, 2006 | 01:51 AM
HT Black OPs
Default Re: (no2unenolife)
Search made topics by me. I did a DIY on how to remove the door handles. And i too have a DB, and Type R door panels.
Old Apr 10, 2006 | 07:41 AM
infulleffect's Avatar
Default Re: (00IntegrAllmotoR)
The top prob will be tight...spray some WD-40 there and let it sit. Then take a larger screw driver and pry between the rod and the handle and it will begin move.
Old Apr 10, 2006 | 07:45 AM
AnthraxVX's Avatar
with magic. ... also known as helms
Old Apr 10, 2006 | 07:49 AM
HT Black OPs
Default Re: how to remove outer door handle?? (AnthraxVX)
https://honda-tech.com/zerothread?id=1496564
middle of first page.
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
todd.ludwig
May 1, 2006 02:27 AM
Kenshou Motorsports
Dec 30, 2004 12:41 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
