Question on headers.....?
Old Mar 11, 2006 | 08:57 PM
jdmdc2110's Avatar
Default Question on headers.....?
I bought a header from a friend (no name brand, ebay special i think), he took it off of his car because it was too low. It is a 4-1 header but my question is, I have a 2001 GSR and he took it off of his 1996 LS. Will it fit on fine???
Modified by jdmdc2110 at 5:45 AM 3/13/2006
Old Mar 11, 2006 | 09:28 PM
Padawan's Avatar
Darth ModerVader
Default Re: Question on headers.....? (jdmdc2110)
If his car is indeed a '94 LS, and he had purchased the correct header for it, then it will bolt right up to your '01 GS-R.
Old Mar 11, 2006 | 09:33 PM
jdmdc2110's Avatar
Default Re: Question on headers.....? (Padawan)
yea its between a 94-97 LS and he bolted on there but only for about 20 miles and he says it did fine so i wasnt sure if it would bolt on mine fine or not
Old Mar 11, 2006 | 10:33 PM
tomithy's Avatar
for what i've heard pretty much all header/cat/exhaust for intergras 94+ should fit for each other except for 94-99 gs-r's
Old Mar 13, 2006 | 04:44 AM
jdmdc2110's Avatar
Default Re: (tomithy)
alright thanks, found out that the other integra guy i bought it from is a 96 but shouldnt make any difference, if you still know the answer to my question post it. thanks
Old Mar 13, 2006 | 06:14 AM
Uncle Willie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If his car is indeed a '94 LS, and he had purchased the correct header for it, then it will bolt right up to your '01 GS-R.</TD></TR></TABLE>
I am suprised by this info. Intake manifolds are not interchangeable between the ls and gsr, so i am suprised that the exhaust manifold is interchangeable. Anyone else back Padawans info up?
Old Mar 13, 2006 | 06:18 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Question on headers.....? (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">I am suprised by this info. Intake manifolds are not interchangeable between the ls and gsr, so i am suprised that the exhaust manifold is interchangeable. Anyone else back Padawans info up?</TD></TR></TABLE>
The Only difference in the exhaust manifolds is length on the bottom.
They all bolt up the same.
Old Mar 13, 2006 | 07:03 AM
Micha's Avatar
FAILWGN
Default Re: Question on headers.....? (FlatBlackTeg)
The only ones that are different are the 94-99 GSR's.
Old Mar 13, 2006 | 07:36 AM
1337whp's Avatar
Default Re: Question on headers.....? (Blu99teg)
i would think thier the same but then
Intake manifolds are not interchangeable between the ls and gsr, so i am suprised that the exhaust manifold is interchangeable.</TD></TR></TABLE>
i dont think theyd fit, and if its a tr header it definitly wont fit; unless it has new brackets or something
Old Mar 13, 2006 | 12:31 PM
Hype-R Stalker
Default Re: Question on headers.....? (1337whp)
There is no difference in bolt pattern, only in length.
Old Mar 13, 2006 | 02:09 PM
dc2nick's Avatar
Exactly. The legnth difference is caused by the O2 Sensor Bung. in the 94-99 GS-R, BOTH O2 sensors screw into the CAT. The rest all have the bung BEFORE the flange for the Cat.
Old Mar 13, 2006 | 02:19 PM
Padawan's Avatar
Darth ModerVader
For a quick example, check out Comptech's website and you'll discover that the headers for the '00-'01 GS-R, the '97-'01 ITR, and the '94-'01 LS, RS, GS all share the same part number.
As I stated earlier, they're completely interchangeable.
Old Mar 13, 2006 | 07:14 PM
jdmdc2110's Avatar
thanks for all the info
Old Mar 13, 2006 | 07:17 PM
petergriffen's Avatar
intake manifolds are not interchageble between an ls and a gsr. you can take a type-r manifold and put it on a b16 though i can back all of this up
Old Mar 13, 2006 | 07:18 PM
teggy182's Avatar
should fit no problem
Old Mar 13, 2006 | 07:58 PM
Hype-R Stalker
Default Re: Question on headers.....? (petergriffen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petergriffen &raquo;</TD></TR><TR><TD CLASS="quote">intake manifolds are not interchageble between an ls and a gsr. you can take a type-r manifold and put it on a b16 though i can back all of this up</TD></TR></TABLE>
Awesome, what did we need to know about that for again?
Old Mar 14, 2006 | 06:40 PM
jdmdc2110's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">
haha yea im am only wondering about exhaust manifolds, nothing about intake manifolds
bomber19
Jan 7, 2008 08:41 PM
fitbmx86
14
May 2, 2007 12:14 PM
93h22a1vtec
Jan 11, 2006 06:21 PM
mkiv98
Jan 8, 2005 05:57 PM
s2k_al
Sep 7, 2004 09:37 AM
