Do I need to put this back on? (sensor on the back of the block)
Old Mar 11, 2006 | 11:47 AM
Alex_G's Avatar
Occupy GDD
Default Do I need to put this back on? (sensor on the back of the block)
On the back of the b18a1 there is a sensor that b20b doesn't have. Do I need to swap it to the b20? I'm not sure what its called but its close to the oil filter.
Please someone help me I'm working on this right now and I don't know if I need it or now thanks!
Old Mar 11, 2006 | 12:14 PM
sykotic's Avatar
Default Re: Do I need to put this back on? (Alex_G)
Is it this hole?(the one the blue arrow is pointing to) If so, yes you need it, it is the oil pressure sensor.
Old Mar 11, 2006 | 12:29 PM
Alex_G's Avatar
Occupy GDD
Default Re: Do I need to put this back on? (sykotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">Is it this hole?(the one the blue arrow is pointing to) If so, yes you need it, it is the oil pressure sensor.
Hmm it looks different I think. I'm gonna take a pic of it right now
Old Mar 11, 2006 | 12:37 PM
Alex_G's Avatar
Occupy GDD
This one is a pic of the b18a1
This is the b20b
Old Mar 11, 2006 | 01:00 PM
Alex_G's Avatar
Occupy GDD
Anyone know if I need to put that sensor on the b20 in order for my car to run correctly? And if I do man that thing is a pain in the *** to take off.
Old Mar 11, 2006 | 02:05 PM
Alex_G's Avatar
Occupy GDD
TTT
Old Mar 11, 2006 | 02:18 PM
Azn Kenny's Avatar
You don't need it for it to run, it just connects to a wire that goes tot he check oil light but be sure to plug it up or it will leak oil.
Old Mar 11, 2006 | 02:51 PM
JDMorgan's Avatar
Default Re: (LSntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSntegra &raquo;</TD></TR><TR><TD CLASS="quote">You don't need it for it to run, it just connects to a wire that goes tot he check oil light but be sure to plug it up or it will leak oil.</TD></TR></TABLE>
Old Mar 11, 2006 | 02:58 PM
Alex_G's Avatar
Occupy GDD
Default Re: (KraZEtEggIE)
Just want to make sure but you guys are talking about the green sensor right? The other one next to that one I already swapped. So the green one I can leave alone, I don't have to put it on the b20?
Old Mar 11, 2006 | 03:42 PM
J.nguyen's Avatar
Default Re: (Alex_G)
omg.. doess uhmm the b18b1 have the same setup?? because im missing 2 holes in the back of my block by oil filter too... and am i leaking oilll?
Old Mar 11, 2006 | 04:45 PM
sykotic's Avatar
oh i see what you're talking about, i'm not real sure what that is but that's a freeze plug it's in. you shouldn't need it, im going to look it up though to find out what it is.
Old Mar 11, 2006 | 05:10 PM
b20integrapower's Avatar
Default Re: (sykotic)
i believe that is the crank speed flucuation sensor...b20b's do not have them and the ls motors do..you DO NOT need to change it..but u will throw a check engine if u are using stock obd2 ecu...i have a b20b..and i got a obd1 jumper harness and obd1 ls ecu and cleared the cel...good luck
Old Mar 11, 2006 | 05:23 PM
92integra-R's Avatar
im doing a swap on my 92 integra, im swapping for a c5, and my a1 of couse has that same sensor, but not on the c5. what do i do?
see the c5 dosnt have it
Old Mar 11, 2006 | 07:23 PM
Diego Dangers.'s Avatar
Default Re: Do I need to put this back on? (92integra-R)
92integra-R are you going to run obd2? if not, dont worry about it, guy gave a fix up there.
Old Mar 11, 2006 | 09:18 PM
LeftCorner's Avatar
That green plug is found only on the 92-93 DA's that had A/C. It reads oil temp. and is only a ref. input to the ECU. You don't need to swap it over to your B20 and it won't cause a CEL.
Old Mar 17, 2006 | 02:24 PM
Default Re: Do I need to put this back on? (Diego Dangers.)
no im going to run obd1... thanks for the help
Old Mar 17, 2006 | 04:20 PM
Echo7847's Avatar
Default Re: (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">i believe that is the crank speed flucuation sensor...b20b's do not have them and the ls motors do..you DO NOT need to change it..but u will throw a check engine if u are using stock obd2 ecu...i have a b20b..and i got a obd1 jumper harness and obd1 ls ecu and cleared the cel...good luck</TD></TR></TABLE>
Wow......
Oil pressure sensor, yes you need to swap them over. Be sure to use Hondabond or permatex on the threads when u re-install it.
joedr
Nov 9, 2008 12:11 PM
h22_crx
Jan 19, 2007 03:06 PM
vtecb20coupe
Jul 5, 2004 07:34 PM
90teg
Jul 31, 2003 05:30 PM
infamousALLMTR
Apr 15, 2002 02:36 PM
