Compressor map help
Old May 26, 2006 | 05:48 PM
shadyGs-R's Avatar
Default Compressor map help
alright im almost there. ill tell you guys what i have done and what i dont have done. i have the Pressure ratio down. 14.7+boost/divided 14.7 =Pressure ratio absolute. is that right? that will deterime if i want a turbo at low boost or high boost? is that correct? the only thing i understand about the surge limit is that it is bad and do not want to be on the left side of it. i do not understand how you get the air flow or CFM. i also understand at the right side of the map those numbers are compressors RPM. i do not understand what that red line is and why there is percentage in the middle of the islands. and i dont understand what the islands are. i read all that stuff nd still dont understand can somebody please explain it to me. and i have one more question. are all the compressor maps based on Pressure ratio and Airflow. or is there other stuff that they can put at the X and Y axis other than Pressure ratio and CFM airflow?
Modified by shadyGs-R at 2:20 PM 5/27/2006
Loudk
Jan 7, 2013 03:53 PM
erikiksaz1
Jun 12, 2007 10:32 AM
shadyGs-R
May 28, 2006 12:54 PM
b18bEKcoupe
Apr 12, 2005 07:27 PM
sweettooth
Apr 27, 2002 08:33 AM
