MAP. Code 3, lose wires etc.
Popped a 3 code. Map sensor. When i touch the harness that goes to the ECU plugs while the car is off, restart the car, engine light dissapears. I suppose the wire got lose somewhere. I reset the ECU, drive around. The code once awhile pops back again. Car also acts very jerky.
Can someone tell me the MAP pin location on the plugs so i can trace the wire? Could it be the connectors to the VAFC that i wired up? But i looked on the diagram of the VAFC and there is no wire going to MAP sensor. Unless they called it different.
Or you guys think that the problem is in the sensor itself?
Thanks.
Thanks.
Guest
Posts: n/a
*codes below*
I would check your wires use a continuity tester make sure they are connected all the way to the ecu.
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
67 Catalyst low efficiency. (same as P0420)
70 Automatic Transmission Malfunction w/AT Controls
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Evaporative Emission Control System insufficient purge flow
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
Guest
Posts: n/a
*codes below*
edit: to find the pinout just search "pinout" and the ecu you're running. its pretty simple to find a chart or pic of it.
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
mr2turbo007
Apr 23, 2012 06:22 PM
FSUseminoleEM1
Feb 19, 2010 08:34 AM
gokuson
Mar 18, 2003 07:27 PM
