LSD question
Old May 26, 2006 | 05:44 PM
lastpunkinline's Avatar
Default LSD question
If you don't have LSD your passanger side wheel should leave tire marks when you burn out right? well I thought with LSD both tires should leave tire marks. But my car only leaves tire marks on the drivers side? Is there something weird going on?
Old May 26, 2006 | 06:24 PM
BOOSTED RIVAL's Avatar
Default Re: LSD question (lastpunkinline)
With LSD both tire will spin in a straight line, but with out and you try to do a burn out most of the time one tire will just keep spining and one will stop.
Old May 27, 2006 | 10:25 AM
Default Re: LSD question (BOOSTED RIVIL)
but isn't the tire thats suppose to spin is the passanger side because the trannys right there with that axle???
Old May 27, 2006 | 10:38 AM
RacerMike's Avatar
What kind of LSD and was it new or used?
Mike
Old May 27, 2006 | 10:42 AM
akstunt600's Avatar
phnatom grips unless they r green spring normally dont work just dumping the clutch. u have to **** the wheel to one side
u can kinda see by pulling out one of ur axels. but u should pull both out to check. if u can see right through its a true lsd. if u see a shaft in the center its an opend diff. and if its a phantom u cant really see threw
Old May 27, 2006 | 10:43 AM
Default Re: (akstunt600)
some guy was trying to explain to me that it has to do with the clutch????
Old May 27, 2006 | 10:49 AM
akstunt600's Avatar
lol, no it doesnt matter if its some crazy twin plate or a slipping stock clutch both tires should spin
however if the diff is beat up the tiny clutches inside maybe too worn too get both axels transfering torque
Old May 27, 2006 | 11:31 AM
Well yea he was saying that it was a oem lsd clutch and thats wut made it only spin the tire from the passenger side??
Old May 27, 2006 | 11:59 AM
akstunt600's Avatar
both tires will spin even on a oem clutch type lsd that is near the end of its life span
he is a lying sack of **** unless he was really able to demolish the clutches completely in the lsd
Old May 27, 2006 | 12:59 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline &raquo;</TD></TR><TR><TD CLASS="quote">but isn't the tire thats suppose to spin is the passanger side because the trannys right there with that axle???</TD></TR></TABLE>
The tire that will spin will be the one with less weight sitting on it, or the one with less traction. And as everybody else said, with an LSD, they should both spin.
Old May 27, 2006 | 03:41 PM
k624ash's Avatar
Default Re: LSD question (02 accord)
are you sure you have an lsd? put your car up on jack stands and spin one wheel with your hands, if the one on the other side spins the same direction you have an lsd. if it spins the opposite direction you dont. and i belive it has to be in gear.
someone correct me if i got it wrong
Old May 27, 2006 | 03:56 PM
02 accord's Avatar
Default Re: LSD question (k624ash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k624ash &raquo;</TD></TR><TR><TD CLASS="quote">are you sure you have an lsd? put your car up on jack stands and spin one wheel with your hands, if the one on the other side spins the same direction you have an lsd. if it spins the opposite direction you dont. and i belive it has to be in gear.
someone correct me if i got it wrong</TD></TR></TABLE>
Close. With the car in gear, if you can spin one wheel and the other one spins the opposite way, no LSD. If you do have an LSD, you should not be able to spin either wheel, because then, you will be trying to spin the engine as well. Also with an LSD, with the car in neutral, both wheels should spin the same way.
combos99
Feb 18, 2008 06:08 PM
gophat
Sep 2, 2006 09:27 AM
b16a27
12
Oct 26, 2004 08:25 PM
Wrath of VTEC
Dec 1, 2003 12:04 AM
EF_LSVtec
16
Sep 18, 2002 10:59 AM
