engine chokes when given gas
Old May 23, 2006 | 05:59 PM
sorrule's Avatar
Default engine chokes when given gas
My buddies and I are stumped on this one. The car is a 95 acura integra GSR. We recently replaced the head and now it isn't working right. The motor idles good and doesn't throw any codes, but when we step on the gas the engine bogs and chokes like it's gonna die. What do you guys think it could be. Could it not be getting enough gas? We swap fuel rails and injectors from a running car. So what the heck it wrong with it.
Old May 23, 2006 | 06:09 PM
TeriyakiTeg's Avatar
check your timming you may have put it on 1tooth off
try full advance on the dist and see if the motor runns any better
i changed the t-belt on my motor and was one tooth off and had a similar issue hope that helps
Old May 24, 2006 | 09:26 AM
sorrule's Avatar
Default Re: (TeriyakiTeg)
I'll try that, haven't advance or retarded the ignition timing yet.
Old May 24, 2006 | 09:38 AM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: engine chokes when given gas (sorrule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sorrule &raquo;</TD></TR><TR><TD CLASS="quote">My buddies and I are stumped on this one. The car is a 95 acura integra GSR. We recently replaced the head and now it isn't working right. The motor idles good and doesn't throw any codes, but when we step on the gas the engine bogs and chokes like it's gonna die. What do you guys think it could be. Could it not be getting enough gas? We swap fuel rails and injectors from a running car. So what the heck it wrong with it.</TD></TR></TABLE>
you can also check ur fuel filter, fuel pressure regulator, and fuel pump
Old May 24, 2006 | 05:26 PM
sorrule's Avatar
well it's weird, because my buddy bought it from some dumbazz who made the motor *** up. It was still running, but some of the valves were bent, the timing belt was "jumping" or skipping, he rev'd it up so high that the alternator belt broke too. So maybe the timing is just off. I'll see tomorrow.
team_lunatics
Nov 10, 2011 08:18 PM
AnnaMarie
Feb 28, 2008 12:40 PM
alduron
Nov 8, 2006 06:55 PM
BigPlansNoMoney
Nov 8, 2004 09:13 AM
dpo95si
May 1, 2003 01:04 PM
