vtec head
Old May 23, 2006 | 09:42 PM
B-JUSTINE's Avatar
Default vtec head
what would b the BEST vtec head (price aside) for my lsvtec setup?
how and why. thanx
Old May 23, 2006 | 10:10 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: vtec head (B-JUSTINE)
well b16 heads are cheap, GSR might be better for the money, and type R are the more expensive heads.
because the LS is 1.8, i would stick with at least a GSR head
Old May 23, 2006 | 11:38 PM
VHOA's Avatar
Default Re: (z51C6)
c5 head hands down its already ported comes with cams and it IS the best motor to use it comes out of a 1.8 (if they even makes a difference)
Old May 24, 2006 | 12:23 AM
CivicFreak's Avatar
i would go with b16 head cause its similar to type r head and its less expensive.
i've seen and lot of ls vtec people going with b16 head
Old May 24, 2006 | 12:33 AM
tomlinson619's Avatar
Default Re: vtec head (CivicFreak)
b16 head
Old May 24, 2006 | 09:22 AM
Default Re: vtec head (jdmb18ckid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-JUSTINE &raquo;</TD></TR><TR><TD CLASS="quote">what would b the BEST vtec head (price aside) for my lsvtec setup?
how and why. thanx</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb18ckid &raquo;</TD></TR><TR><TD CLASS="quote">b16 head</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z51C6 &raquo;</TD></TR><TR><TD CLASS="quote">b18c1 head. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VHOA &raquo;</TD></TR><TR><TD CLASS="quote">c5 head hands down its already ported comes with cams and it IS the best motor to use it comes out of a 1.8 (if they even makes a difference)</TD></TR></TABLE>
haha notice everyone has there own preference, just pick up the first vtec head you come across. you get what you pay for b16 &lt; b18c1 &lt; b18c5
Old May 24, 2006 | 10:41 AM
VHOA's Avatar
Default Re: vtec head (JDM turbo DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFreak &raquo;</TD></TR><TR><TD CLASS="quote">i would go with b16 head cause its similar to type r head and its less expensive.
i've seen and lot of ls vtec people going with b16 head</TD></TR></TABLE>
I dont like stupid people like you, he said he didnt care money wise so why would you get a head that produces less power?
Old May 24, 2006 | 10:45 AM
kangbang's Avatar
i'm going down the same route ls/vtec-wise and i was wondering what the vtec powerbands were, like from what rpm to what for each head. plus which head creates the least problems, or are they all good mechanically.
Old May 24, 2006 | 10:58 AM
Default Re: (kangbang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kangbang &raquo;</TD></TR><TR><TD CLASS="quote">i'm going down the same route ls/vtec-wise and i was wondering what the vtec powerbands were, like from what rpm to what for each head. plus which head creates the least problems, or are they all good mechanically.</TD></TR></TABLE>
since the LS block is a 1.8L, ive heard that GSR and Type R heads will function mechanically better because they are meant for 1.8L. im not saying the b16 won't work but the GSR and Type R head will definately flow much better. From GSR to Type R, the Type R cams are what makes the Type R head flow better from the GSR.
Old May 24, 2006 | 12:37 PM
CivicFreak's Avatar
Default Re: vtec head (VHOA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VHOA &raquo;</TD></TR><TR><TD CLASS="quote">I dont like stupid people like you, he said he didnt care money wise so why would you get a head that produces less power?</TD></TR></TABLE>
read this https://honda-tech.com/zerothread?id=469492 , well if money is not a problem, why would he ask the question? he would just pick up a ITR head for the damn project. Every **** we do to our cars has limited budget.
"the range of lift that normal camshafts utilize is where the b16 outflows the b18. the b18 head only outflows the b16 head after .475 valve lift. no streetable cam lifts that much.the b16 head flows a little better than the b18 head"
ps, there is no need for harsh words, i'm just simply trying to help man.
Old May 24, 2006 | 05:00 PM
kangbang's Avatar
wow, good info on that thread. b16 head it is!
Old May 24, 2006 | 05:14 PM
cm zak's Avatar
do a poor man, except i guess you'll have a LS block
Old May 24, 2006 | 05:25 PM
ecks_fourttwo's Avatar
c5....hands up, down, and all around!!!
Old May 26, 2006 | 02:22 PM
B-JUSTINE's Avatar
thanx for all the input guys
i guess it just is a matter of opinion
i was initially thinkin c5, but now after all this input
plus a lil of my own research im thinking b16b
thanx again guys, uve been more than helpful
Old May 26, 2006 | 02:29 PM
jdm_bones's Avatar
Check the sig...Go C5
Old May 26, 2006 | 02:38 PM
b20powereDA's Avatar
Default Re: vtec head (jdm_bones)
jus for the record it doesnt matter what if the block came of a 1.6 or a 1.8. cause a b16 head and type r head are the same casting jus type r head has differnt valvetrain, cams, im, and comes ported from the factory. hence the combustion chambers on a b16 are al 81 mm jus like every oither b-series vtec head
96ej8MR
Jun 27, 2007 06:28 PM
cars101
11
May 3, 2006 04:56 PM
Carbon_Lude98
Oct 15, 2004 04:25 PM
the DA in HONDA
Jul 26, 2004 05:13 AM
LSHatchback
22
Jun 12, 2003 12:01 PM
