Fuel Pump.
Old May 26, 2006 | 05:15 PM
cifer6425's Avatar
Default Fuel Pump now no start and no spark.
we got a problem with an 90 integra. it will not start. we have replace batter, starter, plugs, wires, all the basic stuff. yesterday i was helping my friend, and we started to trouble shoot the fuel system the best we could. when we disconnect the fuel lines from the fuel filter and tried to crank the car, no fuel came out. we replaced the fuel relay as well. i am thinking it is the fuel pump. my only other concern is there an alarm on the car and maybe that is cutting power to the fuel pump.
any thoughts are suggestions?
thanks
Modified by cifer6425 at 4:25 AM 5/31/2006
Old May 26, 2006 | 06:16 PM
BOOSTED RIVAL's Avatar
Default Re: Fuel Pump. (cifer6425)
Most alarm don't cut fuel pump it only cut ignition so it got to be a bad fuel pump.
Old May 26, 2006 | 07:30 PM
cifer6425's Avatar
Default Re: Fuel Pump. (BOOSTED RIVIL)
thanks.
Old May 28, 2006 | 02:38 PM
cifer6425's Avatar
replaced fuel pump, pick up screen and fuel filter today. still no go.
i wired the old fuel pump up to the batter directly and it started pumping.
i need to double check the person i got the car from and see if he replaced the relay.
what are the odds of a block line some where?
any suggestions?
thanks.
Old May 29, 2006 | 06:21 AM
stepka001's Avatar
It's your relay man, you didn't need to replace the pump. TRUST ME!!!!!!
Old May 29, 2006 | 08:45 AM
qfast817's Avatar
Default Re: Fuel Pump. (stepka001)
does the motor build compression? i would check the timming belt if not
Old May 29, 2006 | 02:35 PM
cifer6425's Avatar
Default Re: Fuel Pump. (qfast817)
not the fuel relay. i just replaced it. thank you.
how would i check if the motor is building compression?
Old May 31, 2006 | 12:25 AM
cifer6425's Avatar
ok so tonight, i tested the spark plugs out. removed the plug from engine, pluged into wire and tried to start. expecting to see a spark across the gap. i did not see a spark across the gap. so i now assume that is has something to do with no spark.
arg.
any suggestions?
Old May 31, 2006 | 08:17 PM
ITR#132's Avatar
if you have no fuel and no spark, its a bad ecu
Old May 31, 2006 | 08:45 PM
cifer6425's Avatar
Default Re: (ITR#132)
anyone got a spare ECU they are willing to let me borrow?
Old Jun 3, 2006 | 12:21 AM
cifer6425's Avatar
Default Re: (cifer6425)
well i have discovered that the CEL stays on for more than 2 seconds when first turning the car on. i believe the ecu code is a PR4. tomorrow i will look at how to test it.
it does appear that the ecu is not the orginal, or has been removed modified before.
Old Jun 9, 2006 | 06:53 PM
stepka001's Avatar
Ignitor?
pappasmurf
Nov 11, 2024 07:43 AM
enriquev
Oct 11, 2007 05:31 PM
Cameron60
Jan 16, 2007 06:04 PM
Z6REX-SI
10
Mar 9, 2004 07:50 AM
