AC bracket removal
Old Sep 8, 2006 | 08:46 AM
Integra4106's Avatar
Default AC bracket removal
I am doing a wire tuck to my GSR. I eliminated my AC lines and I want to eliminate my condensor but keep power steering. I have looked at this article https://honda-tech.com/zerothread?id=1693934 and it seems to be that no one has the drivers side lower motor mount bracket that is behind the AC compressor. Do you need this bracket or could i remove it w/o having any problems? Thanks
Old Sep 8, 2006 | 09:10 AM
DC2 Mang's Avatar
Default Re: AC bracket removal (Integra4106)
I have had mine off for a while without any problems
there are 4 bolts, remove them and then a 17mm nut on the bar that goes throguh the mount on the chasis, just remove the nut after the bolts on the block are out and the bracket should come right off
Old Sep 8, 2006 | 09:53 AM
B2FiNiTY's Avatar
Default Re: AC bracket removal (DC2 Mang)
You can run without but it is best to keep it as it serves as a vibration mount. Unless you have upgraded mounts elsewhere, I highly suggest running it.
Just get the JDM aluminum one and it'll be bling
Old Sep 8, 2006 | 09:59 AM
Default Re: AC bracket removal (B2FiNiTY)
where can i find this jdm aluminum bracket
Old Sep 8, 2006 | 10:33 AM
DC2 Mang's Avatar
passwordjdm, inlinefour, jhpusa
im sure all of them have the aluminum brackets
brainplant38
Aug 4, 2014 04:21 PM
rasinhell
Mar 18, 2005 08:45 AM
Renegade
Jan 28, 2005 07:39 AM
SLeePeR012
Feb 21, 2004 04:43 PM
NeXtLeVeL_TyPe_R
Nov 24, 2002 07:47 PM
