shaking Engine!!!!!!!!!!!
got a problem gay **** my Gsr sakes side to side only when i gas it feels like the engine mounts lose or mess up but dont realy know for shure cant figure out wat the expletive wrong with it and some times the problem gose away on the high way only happens when i apply gas but when i clutch it it goes away got any idea wat it could be???? my aim is elusivesximage need help ASAP
i think its shot cause i can shake the engine with my hand when i pull on the intake manifold soo if the mounts all shot would that cause the engine to Shake the car likeCRAZY ???? this started to happen when i lower the car i check the sespension though all bolts tight and the bushin on the struts good though i donno it shakes mad hard only when i gas it though
I agree with rhtuner, double check eveything and make sure every mounts is toruqed down to specs. And yes bad mounts would allow the enginge to shake. Think of it as a large circle O and then a smaller --- shaft(i know it sounds messed up) with all that extra room it just gives it more play...Hope that helped a little
if its your motormounts try http://www.innovativemounts.com if you plan on upgrading to stronger mounts.
the mounts are shot. done You say it started after lowering the car. I'm betting the car is really low. maybe the axle is actually binding or is the car misfireing? A misfire wouldn't be as prevalent at highway speeds? just a thought. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnnyboi4o1 »</TD></TR><TR><TD CLASS="quote">i think its my axel cause i kinda shot my strute and it landed on my axel .... no spring compresor
Hahaha, you just shot the shock off? How far did it fly?
If you don't have a spring compressor you're supposed to lay the shock/spring flat on the ground with a wheel at each end to keep everything together when it explodes apart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 »</TD></TR><TR><TD CLASS="quote">get new motor mounts and poly urethene bushings. </TD></TR></TABLE>
First check which ones are bad/look bad, then either get a new mount or an aftermarket insert.
If you don't have a spring compressor you're supposed to lay the shock/spring flat on the ground with a wheel at each end to keep everything together when it explodes apart.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 »</TD></TR><TR><TD CLASS="quote">get new motor mounts and poly urethene bushings. </TD></TR></TABLE>
hey its the mounts for sure man...my integra is doing the same, i can rock my engine and it fells like it bounces when i let go of the gas peddle...also my shifter shakes too...have not change it yet, but i know for sure its the mounts...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnnyboi4o1 »</TD></TR><TR><TD CLASS="quote">got a problem gay **** my Gsr sakes side to side only when i gas it feels like the engine mounts lose or mess up but dont realy know for shure cant figure out wat the expletive wrong with it and some times the problem gose away on the high way only happens when i apply gas but when i clutch it it goes away got any idea wat it could be???? my aim is elusivesximage need help ASAP</TD></TR></TABLE>
Just get polyurethane motormount inserts from http://www.energysuspension.com
it was the axelz haha replace both and the shaking stop but still need new mounts im also looking for a good suspention set up dont give a **** about comfert just need GOOD perfomence
