Manual conversion
Old Sep 7, 2006 | 07:54 PM
hamonangan2006's Avatar
Default Manual conversion
hello everyone, im trying to convert my auto to stick any ideas or refrences-because the auto suck(no offense) so what do i need beside transmission and pedal assembly? thanks appriciate it----maybe some pics
Old Sep 7, 2006 | 08:17 PM
db84lifex's Avatar
Default Re: Manual conversion (hamonangan2006)
manual ecu, clutch master cylinder, clutch set, fly wheel, with bolts, slave cylinder, manual line, or custom , shifter assembly, gauge cluster, but can use ur stock... juz use a after market gauge ... like a reverse gauge.. i think thats what its call.....
Old Sep 7, 2006 | 08:21 PM
btech's Avatar
Default Re: Manual conversion (db84lifex)
i have an obd1 ecu for sale.. 5-speed manual of a 95 integra LS.
Old Sep 8, 2006 | 07:19 AM
XxNampsterxX's Avatar
You're also gonna need to get a auto to manual tranny mount, unless you want your shop to cut and reweld your mount. project dc2 sells them.
Old Sep 8, 2006 | 10:04 AM
ez12a's Avatar
we dont even know what year integra it is. if its 90-93 you do not need a clutch master cylinder.
Old Sep 8, 2006 | 11:03 AM
SilverDc2's Avatar
Default Re: (ez12a)
search, there's a lot of research done,
i did it to my car, you can search under my name or shammoo something like that, there's a lot of info out there.
Old Sep 8, 2006 | 11:07 AM
MastaJae's Avatar
when searching, make sure you click on archived threads... or else you may come up with nothing
Old Sep 8, 2006 | 12:25 PM
guttedLS's Avatar
Default Re: Manual conversion (MastaJae)
What i did when i did the conversion on my car was to buy a wrecked car for cheap. I had a second set of parts incase of losing anything and everything that i needed was already on that car, so i didn't have to buy much else.
Old Sep 8, 2006 | 01:03 PM
xteg95's Avatar
Default Re: Manual conversion (guttedLS)
https://honda-tech.com/zerothread?id=273253
FAQ has a lot of good info.
Peruviann83
Jun 29, 2011 02:57 PM
jack-gtir
Jun 23, 2007 08:57 AM
itrcrazy
Jan 26, 2006 05:26 PM
blue_hatch
Mar 17, 2005 10:45 PM
LudeSi-93
Dec 26, 2002 08:04 AM
