Help...Low Compression/Drop!
Old Sep 7, 2006 | 03:43 PM
Weapon X's Avatar
Default Help...Low Compression/Drop!
I just did a compression test and my result are:
Cyl 1: 150
Cyl 2: 120
Cyl 3: 120
Cyl 4: 150
But the number drop all the way down to 0... is it my piston rings? can anyone tell me what's wrong?
thanks...
Old Sep 7, 2006 | 03:46 PM
unknown0001's Avatar
Default Re: Help...Low Compression/Drop! (DC4 KiDD)
What kind engine? how many km?
how is your timing set? properly? because an open valve(s) could cause the combustion chamber from holding compression
Old Sep 7, 2006 | 03:51 PM
Weapon X's Avatar
Default Re: Help...Low Compression/Drop! (Mr.RHTuner)
It's a B18B1 w/ 163,xxx miles. I'm not sure if my timing is set properly. I just had the car for a month.
Old Sep 7, 2006 | 03:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4 KiDD &raquo;</TD></TR><TR><TD CLASS="quote">It's a B18B1 w/ 163,xxx miles. I'm not sure if my timing is set properly. I just had the car for a month. </TD></TR></TABLE>
How does it run normally? does it feel ***** slow or lacking performance???
I recomend you re-set your timing and do a valve adjustment and then do a compression test to eliminate false timing as a problem.
It could be piston rings at worst. Does it burn oil? when you drive it or drive it hard do your buddie say you have blue exhaust smoke comming from rear?
Old Sep 7, 2006 | 04:03 PM
Weapon X's Avatar
It runs normal no lack of performance. I don't think it burn any oil because there isn't any blue smoke coming out of the exhaust.
Old Sep 7, 2006 | 04:18 PM
mike9571's Avatar
When you did the test was it up to normal operating temp?
Old Sep 7, 2006 | 04:21 PM
Weapon X's Avatar
Default Re: Help...Low Compression/Drop! (mike9571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">When you did the test was it up to normal operating temp?</TD></TR></TABLE>
Yea... I was driving it around for about half an hour.
Old Sep 7, 2006 | 06:03 PM
KWayRacing's Avatar
did you have the "pedal to the metal" while you were testing? you should always open the throttle fully with the ignition disabled when checking compression. Why were checking compression anyway?
Old Sep 7, 2006 | 06:05 PM
Weapon X's Avatar
Default Re: Help...Low Compression/Drop! (KWayRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KWayRacing &raquo;</TD></TR><TR><TD CLASS="quote">did you have the "pedal to the metal" while you were testing? you should always open the throttle fully with the ignition disabled when checking compression. Why were checking compression anyway? </TD></TR></TABLE>
Can't really remember if metal was to the pedal.. .... I'm planning to go turbo that's why i was checking my compression.
Old Sep 8, 2006 | 10:39 AM
Weapon X's Avatar
anyone know why my compression dropped?
Old Sep 8, 2006 | 10:44 AM
DC2 Mang's Avatar
sounds like a leak from the head (valve seals, poor adjustment, etc...)
to check if it in your rings put a little oil i the combustion chamber before you do the test, but usually rings will give you a low reading not lose pressure after you are done cranking the motor
Old Sep 8, 2006 | 01:09 PM
xteg95's Avatar
Can't really remember if metal was to the pedal.. .... I'm planning to go turbo that's why i was checking my compression.</TD></TR></TABLE>
youre planning on going turbo with a block with 163k on it?
Old Sep 8, 2006 | 01:20 PM
Weapon X's Avatar
Default Re: Help...Low Compression/Drop! (xteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg95 &raquo;</TD></TR><TR><TD CLASS="quote">
youre planning on going turbo with a block with 163k on it?</TD></TR></TABLE>
if the motor was healthy yeah.... if not then it's time for a rebuilt.
Samuels
May 26, 2007 08:34 PM
prcivic91
16
Mar 16, 2007 08:33 PM
skunk2415
Sep 9, 2006 05:13 PM
TurboJesse
Sep 23, 2003 06:20 PM
