Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Acura Integra
Reload this Page >
whats the difference between the 94-97 integra from the 98-01 ?
Old 03-07-2007, 12:55 PM
scobaru's Avatar
Default whats the difference between the 94-97 integra from the 98-01 ?
all I know are the front bumpers and wheels are different is there anything else that make the 98-01 different? I've heard the rear bumpers are different too but I can't tell the difference.
scobaru is offline
Old 03-07-2007, 01:07 PM
BoOsTeDtEg81285's Avatar
Default Re: whats the difference between the 94-97 integra from the 98-01 ? (scobaru)
The front bumper, headlight assembly, front corner lights, rear bumper, tailights. Everything on the 98-01 will bolt onto the 94-97, as long as you use correct headlights for the front bumper.
BoOsTeDtEg81285 is offline
Tornadom's Avatar
Front and rear bumpers, headlights, and tail lights, turn signal lamps, wheels, minor chassis reinforcement (to meet stricter safety standards), and color options.
Tornadom is offline
Old 03-07-2007, 01:34 PM
RuskeR's Avatar
Older pic of my GSR. It's a 2000. Notice the more flush front headlights and different front bumper when you compare it to a 94-97. I've got the Type r lip on it in that photo.
RuskeR is offline
Old 03-07-2007, 01:41 PM
143MYVTECEF's Avatar
Default Re: (RuskeR)
Can you post a comparison pic of the differences
143MYVTECEF is offline
teggsr925's Avatar
98+ gsr has adjustable seat height
98+ looks better
94-97 steering wheel says "Acura", 98-01 steering wheel has the "A" symbol
98-01 have a just a fuel lever, no hatch lever
Styling lines were added to the side mirrors in 96. Pre-96 Integras had smooth mirrors
Side door moldings were color-matched to carís body color in 97 for LS models and in 95 for SE models
ODB II Introduced in 1996
Keys have computer chip built-in in 2000
Exhaust system changed in 2000
96 up valve cover on LS is flat across over the cam section, 94-95 cover has raised parts over the cam section.
teggsr925 is offline
Old 03-07-2007, 01:44 PM
teggsr925's Avatar
Default Re: (143MYVTECEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 143MYVTECEF &raquo;</TD></TR><TR><TD CLASS="quote">Can you post a comparison pic of the differences </TD></TR></TABLE>
go here
http://www.team-integra.net/se...D=480
Old 03-07-2007, 01:50 PM
iH8RICERZ's Avatar
Default Re: (teggsr925)
Differences
# 98-01 front bumper is more aggressive looking
# 98-01 rear bumper has air dam
# Headlights are different size
# Bumper lights are different size
# 98-01 taillights are all red, 94-97 has amber turn signals
# 94-97 steering wheel says "Acura", 98-01 steering wheel has the "A" symbol
# 98-01 have a just a fuel lever, no hatch lever
Now for the questions people always ask:
The 98-01 front bumper WILL fit on the 94-97 models ONLY if you also change:
# Headlights and bumper lights
# Same with headlights, must change the front bumper to work
# 98-01 bumper lights will NOT fit on the 94-97 bumper and vice-versa
# 98-01 tailights WILL fit on 94-97 models and vice-versa
# 98-01 rear bumper WILL fit on 94-97 models and vice-versa
Here are some other differences found on Gen. 3 Integras that were not exclusive in the 94-97 to 98-01 changes, feel free to [ contact me ] to add to the list:
# Styling lines were added to the side mirrors in 96. Pre-96 Integras had smooth mirrors
# Side door moldings were color-matched to carís body color in 97 for LS models and in 95 for SE models
# ODB II Introduced in 1996
# Keys have computer chip built-in in 2000
# Exhaust system changed in 2000
# 96 up valve cover on LS is flat across over the cam section, 94-95 cover has raised parts over the cam section.
Team-Integra's info!
iH8RICERZ is offline
Old 02-15-2019, 05:30 PM
Luis Beltran's Avatar
[QUOTE=iH8RICERZ;26727802]Differences
Do 96 front signal lights fit 99??
Luis Beltran is offline
Old 02-15-2019, 06:54 PM
tony_2018's Avatar
Does it look anything like post #$
tony_2018 is offline
BOMBCRU
09-02-2005 09:02 AM
phil
06-24-2004 08:43 PM
akaEsCo01
07-21-2003 12:14 PM
ZEXCRX
11-06-2002 02:01 PM
-Darren-
05-31-2002 08:34 PM
Quick Reply: whats the difference between the 94-97 integra from the 98-01 ?
  • Ask a Question
Question Title:
Description:
