odometer not working
Old Mar 7, 2007 | 08:03 AM
K2sInteg98's Avatar
Default odometer not working
hey guys, i have a 98 rs and i just recently swapped my gauge cluster for a gsr gauge cluster, because the cluster i had was automatic. The new cluster i put in was from a 96 so i did the swap the green backing trick and it did work. I was driving around and i noticed when i was driving, my mileage wasnt moving on the odometer. All the plugs are in, it just doesnt move at all. I did change the mileage on the gsr cluster because it was in the 100k+ and changed it to my true mileage, which is 98---. Can changing the numbers cause it not to work? any ideas?
Old Mar 7, 2007 | 09:55 AM
s2kdre's Avatar
Default Re: odometer not working (K2sInteg98)
u might of broke somethin when changin the milage.
Old Mar 7, 2007 | 10:58 AM
K2sInteg98's Avatar
Default Re: odometer not working (s2kdre)
im pretty sure i didnt break anything. they all turned nicely and then i locked them into place. Could it be that one of the numbers didnt get locked in right, and its causing them not to turn?
Old Mar 15, 2007 | 07:44 PM
dracecivic's Avatar
Default crazy speedO (please help)
I drive a 97 civic hatchback and recently all of the sudden the speed jumps but tries to work right. i replaced my vss and gauge cluster and still nothing helps. i dont know what the hell is wrong with my car please help me.
Old Mar 15, 2007 | 09:49 PM
99Geeezer's Avatar
Default Re: crazy speedO (dracecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dracecivic &raquo;</TD></TR><TR><TD CLASS="quote">I drive a 97 civic hatchback and recently all of the sudden the speed jumps but tries to work right. i replaced my vss and gauge cluster and still nothing helps. i dont know what the hell is wrong with my car please help me.</TD></TR></TABLE>
I know you are a noob and all but you shouldn't thread jack. But since you are new, try cleaning the contact for the VSS. My speedo quit and I was about to replace the VSS. But I saw the speedo bounce so I cleaned the contacts and everything was good from then on.
DatOneGuy
20
Jan 25, 2015 10:45 AM
Punkem0tion
Jul 22, 2009 04:19 PM
notsoslow
Jul 22, 2009 10:21 AM
preludepower
15
Nov 24, 2005 10:56 PM
