HUGE SPIKING PROBLEM
Old Mar 7, 2007 | 06:39 PM
FrOsTwHiTeDC4's Avatar
Default HUGE SPIKING PROBLEM
I have a 95 Teg... a 50 trim, 50mm hks wastegate w/ a 11.7 lb spring 450 RC injectors, Walbro 255 lp fuel pump. and im running onlt 3in open down pipe...No boost controller and im spiking like 20lbs. and thats letting off early. once i see that that high i get scared but i dont know why. If any one can help that would be great.
Old Mar 7, 2007 | 06:52 PM
jorge59la's Avatar
Default Re: HUGE SPIKING PROBLEM (FrOsTwHiTeDC4)
are you sure its not ur boost gauge (gone wrong)?
Old Mar 7, 2007 | 06:53 PM
Default Re: HUGE SPIKING PROBLEM (jorge59la)
its not.. its running write vac is almost right other wise im not sure. the gague is fine
Old Mar 7, 2007 | 07:06 PM
bump
Old Mar 7, 2007 | 07:09 PM
crowder13's Avatar
is it internal or external, loosen the little screw thing u probly have it to tight and its causing it to spike but id say that thing feels like a monster on 20 lbs
Old Mar 7, 2007 | 07:17 PM
b00stinblue10's Avatar
Default Re: (crowder13)
what screw this is me again. DIFFERENT NAME... and it does feel like a monster on 20 lbs but ill murder it if i dont figure it out soon HELP ME OUT
Old Mar 7, 2007 | 07:27 PM
crowder13's Avatar
if its an internal, im thinking its external, but if its internal there should be the wastegate and then the WGA arm. and there is like a screw that u can either loosen it or tighten it, this is what i used to turn the boost up on my srt-4 and wrx
crowder13's Avatar
or a lsight possibility of colder weather
Old Mar 7, 2007 | 07:33 PM
sanjay813's Avatar
How have you routed he vaccum lines for the wg? and are you positive the wg spring is 11.7
Old Mar 8, 2007 | 05:17 PM
Default Re: HUGE SPIKING PROBLEM (sanjay813)
positive... External wastegate spring is 11.7 but even the cold weather dosent explain 20 plus. and i have the vac route straight from the turbo
ExVtec
Dec 29, 2008 10:52 AM
millertime1085
Sep 27, 2008 08:11 PM
pbzhb
Feb 19, 2008 11:50 AM
X2BOARD
May 30, 2002 10:09 AM
SlowB16
Apr 17, 2002 08:49 AM
