need help
Old Mar 9, 2007 | 12:53 PM
straightRazor's Avatar
Default need help
dose the mileg on an engine afect the block and crank.
i am buying a b18 block and don't know the mileg on it. i don't want to do a biuld up with new parts and then find out that the block is no good. i am thinking of geting the block exrayed. any thoughts?
plus if any one knows of any problem points an the 91 rs (other than it haveing no ******* power) i would like to know things to look for.'
i am also woundering what lift would be good for cams.
Old Mar 9, 2007 | 04:10 PM
j_bizach's Avatar
Default Re: need help (straightRazor)
Yes milage has a big effect on a block. A high milage block will have worn over stock diameter and willl need a honeing or re-bore. Also you cant X-Ray a block its metal. If you really want the block take it to a machien shop and have them take a look at it. If you decide to buy it, its for sure going to need a blueprint.
Old Mar 11, 2007 | 12:01 AM
Default Re: need help (j_bizach)
thanks
DA9tothewheel
Engine Machining & Assembly
Aug 21, 2016 02:48 AM
fastboy559
Nov 3, 2007 06:00 PM
K_KrazyAzn
Dec 15, 2005 11:37 PM
