chipping ECU
Old Mar 5, 2007 | 11:15 PM
rheyrhey's Avatar
Default chipping ECU
im not too sure if this is the right spot to post this but i have a question. my cousin has a 99 LS integra and we were jus wounding is it worth it to chip an LS ECU or is it a waste of money? and if we do should we expect a big difference???? thank you
Old Mar 5, 2007 | 11:17 PM
unknown0001's Avatar
Default Re: chipping ECU (rheyrhey)
Complete waste of money to 'chip the ecu'...that is unless you are chipping it for the fact of adding turbo/supercharger or having your engine built NA.
Those ebay ECU chips, all they do is eliminate your fuel cutoff and give your ecu richer MAP's
IMO save your money for header/intake/exhaust mods
Old Mar 5, 2007 | 11:31 PM
rheyrhey's Avatar
Default Re: chipping ECU (Mr.RHTuner)
o aiight thanks
Old Mar 6, 2007 | 02:41 AM
martyball619's Avatar
dont get I,H,E for the LS.. it wont do a damn thing. iget some crower cams at least and then chip it or tune it
Old Mar 6, 2007 | 04:23 AM
Exeed's Avatar
Default Re: chipping ECU (DC2SiR)
WHat you have to realise with chipping an ECU is that you're just reworking the fuel MAP, and with the LS, there is little room for improvement to be made because of an engine that wasn't built for performance.
Old Mar 6, 2007 | 09:22 AM
Default Re: chipping ECU (Exeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2SiR &raquo;</TD></TR><TR><TD CLASS="quote"> dont get I,H,E for the LS.. it wont do a damn thing. iget some crower cams at least and then chip it or tune it</TD></TR></TABLE>
I/H/E will always help it, flow in and out more air
example https://honda-tech.com/zerothread/1765855
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exeed &raquo;</TD></TR><TR><TD CLASS="quote">WHat you have to realise with chipping an ECU is that you're just reworking the fuel MAP, and with the LS, there is little room for improvement to be made because of an engine that wasn't built for performance. </TD></TR></TABLE>
correct, but I'd sitll recomend deciding on what you want, getting a exhaust system, good intake and good header then having it tuned to pull out some ponies out of the maps
Old Mar 6, 2007 | 10:26 PM
rheyrhey's Avatar
thanks everyone for all the input. THANK YOU
Battle Cat
Mar 20, 2005 11:37 PM
DOHCon15s
Feb 10, 2004 02:12 PM
TeamMGIperformance
Dec 8, 2003 08:41 PM
DjFreeze
Nov 3, 2002 06:33 AM
