increase compression on lsv....
Old Aug 6, 2007 | 01:59 PM
ls_bitik's Avatar
Default increase compression on lsv....
i was just wondering how can i increase compression on my lsv? (exept pistons) im still building it rght now... already have cams and camgears.... itb... what else.. i know you should take off the middle of the head gasket to increase comp..what else should i do?? thanks for the info guys!!!
Old Aug 6, 2007 | 03:41 PM
coronadrinker's Avatar
Default Re: increase compression on lsv.... (ls_bitik)
use a gsr head as opposed to a b16 head
Old Aug 6, 2007 | 03:43 PM
posHonda's Avatar
with a gsr head youll gain more compression using the same pistons compared to any other B series head so you can go with that as coronadrinker mentioned.
besides that theres the headgasket. and why wouldnt you want to build your motor with forged pistons?
Old Aug 6, 2007 | 09:03 PM
ls_bitik's Avatar
Default Re: (iVteC_PoWeR)
i just wanted to see how much power does the pretty much stock lsv... without buying those things.
Old Aug 6, 2007 | 09:05 PM
K2sInteg98's Avatar
Default Re: (ls_bitik)
everything that they said above, gsr head, head gasket, and you can also get high comp valves
Old Aug 7, 2007 | 04:11 PM
doood's Avatar
been there done that
Default Re: (K2sInteg98)
mill the head or use a thin headgasket. neither of which are ideal.
Old Aug 8, 2007 | 12:54 AM
ls_bitik's Avatar
Default Re: (doood)
ok thats what im going to do.. how bout take one layer from the gasket..?..?..?
Old Aug 8, 2007 | 03:00 PM
personally i would just buy a thinner head gasket, don't be cheap!!!!
Old Aug 8, 2007 | 03:04 PM
posHonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_bitik &raquo;</TD></TR><TR><TD CLASS="quote">i just wanted to see how much power does the pretty much stock lsv... without buying those things. </TD></TR></TABLE>
any headgasket can only do so much. staying at low compression will seriously limit your potential if youre not boosting.
low compression = boost
high compression = N/A
pick one
Old Aug 9, 2007 | 01:15 AM
ls_bitik's Avatar
i just dont have enough $$$ for pistons... but im thinking of boosting that lsv and selling the itb...
Old Aug 9, 2007 | 08:22 AM
dagimp415's Avatar
No offense, but if you need to ask a question like this, I don't think you should be messing with ITBs. I'd suggest selling them. Depending on what you have, you could almost buy an entire forged rotating assembly for the money you spent on a good ITB set-up
djsgtrip
Mar 21, 2007 07:15 PM
kc4door
Jan 22, 2006 05:47 PM
tegasaurus
Dec 23, 2003 02:54 PM
jeremy.
Jul 13, 2003 08:31 AM
OBD-One-Kanobe
Sep 17, 2001 02:54 PM
