high flow cat
Old Aug 4, 2007 | 09:36 AM
SleeperGSR's Avatar
Default high flow cat
I'm trying to keep my car legal. Is there a big difference in running a high flow cat compaired to the stock cat? Motor is a b18c1 port and polish head, skunk 2 valve train, type r pistons, and block was honed. I know i'm not going to be getting an extra 50hp but is it worth all the money. I am getting a type-r header and a cat back exhaust, megan probably. Or could i make the type r cat work, is it the same as a gsr? any info would help.
Old Aug 4, 2007 | 10:34 AM
posHonda's Avatar
the stock cat will be restrictive with an all motor setup or any setup at that. get the high flow
Old Aug 4, 2007 | 01:21 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">the stock cat will be restrictive with an all motor setup or any setup at that. get the high flow</TD></TR></TABLE>
lol ...what are you talking about?
To the OP:
If your setup was a salsa...it would probably be a medium/mild. lol (im not making fun of you, its a nice set up). At this point, you probably wont see too much of a gain from a high flow cat. You might see a couple of horsepower if that. However, sometimes high flow cats cause the CEL to come on on OBD2 cars.
The stock cat is not very restrictive. However, it does have a small diameter. The JDM ITR uses a 2.5'' cat. You could use that but you'd have to buy a clockable flange and reclock your exhaust. The S2000 uses a high flow cat from the factory. I dont know if this would fit onto an integra without modification, though.
Glad you're leaving your cat on.
Dubs13
Sep 30, 2009 01:52 PM
DFWRSXS
20
Jan 8, 2006 05:13 PM
NYStyle
Jul 20, 2005 11:39 AM
disturbd696
35
Jun 4, 2003 12:04 PM
^Sammy]!.
Apr 25, 2003 08:03 PM
