CEL code 67 and ABS code 17
Old Aug 5, 2007 | 04:08 PM
drummr6's Avatar
Default CEL code 67 and ABS code 17
I just picked up a 2000 GSR and its throwin CEL code 67 (Catalyst System Efficiency Below Threshold) and ABS code 17 (wheel senor (open/short to body ground/short to power) RL... does code 67 mean the Cat converter is crap? and I'm guessing for code 17 on the ABS i need to replace the rear left sensor?
Oh and besides that, my antenna is stuck up... I've read about this before with integras... is there a way to fix it? I can still hear the motor for it going when i turn the radio on or off...
any help would be greatly appreciated!
thanks!
Old Aug 6, 2007 | 06:27 PM
drummr6's Avatar
anyone?
Old Aug 14, 2007 | 08:41 AM
drummr6's Avatar
well this is sad... anyone? lol
Old Aug 14, 2007 | 10:16 AM
seaninteg's Avatar
Default Re: (drummr6)
well for the antenna motor you can just disconnect the wires for it and the motor wont run because its disconnected
Old Aug 14, 2007 | 05:29 PM
stumpyf4's Avatar
Default Re: CEL code 67 and ABS code 17 (drummr6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drummr6 &raquo;</TD></TR><TR><TD CLASS="quote">does code 67 mean the Cat converter is crap? </TD></TR></TABLE> Means that the system is not seeing the cat doing it's job. Bad cat can casue this. Also exhaust leak, O2 sensor issue. First check for exhaust leaks (especially the donut gasket). If no exhasut leaks then highly probable that the cat is bad. See if you can find a good used cat.
and I'm guessing for code 17 on the ABS i need to replace the rear left sensor</TD></TR></TABLE>
Check the wiring in the back first, could be a chafed wire. Sensors are pretty pricy. If wiring is okay then most likely the sensor.
Oh and besides that, my antenna is stuck up... I've read about this before with integras... is there a way to fix it? I can still hear the motor for it going when i turn the radio on or off... </TD></TR></TABLE>
Replace the mast, they're cheap. The teeth on the mast reel you have in there now are stripped. New masts usually have instructions for replacing.
http://www.team-integra.net/se...D=914
Old Dec 19, 2010 | 10:14 PM
Mtec8's Avatar
Bringing an old thread back from the dead, didn't want to start a new one. I have the exact same codes on my 2000 GSR. Did you ever get the problems fixed drummr6?
serjey15
Feb 6, 2011 08:11 PM
paniaguae640
May 27, 2008 01:42 PM
fassassin
Jan 8, 2005 05:17 PM
H22A EG6
Dec 22, 2003 01:21 PM
