Head Gasket Question
Old Aug 7, 2007 | 06:07 PM
TruGsr1's Avatar
Default Head Gasket Question
I'm rebuliding my b18c1 and plan on throwin in some itr pistons. What i was wondering was should i run a stock or cometic head gasket. If so how many layers and what size. What would be best to run a safe cr without worryin about detonation
Old Aug 7, 2007 | 06:39 PM
TruGsr1's Avatar
Default Re: Head Gasket Question (TruGsr1)
bump
Old Aug 7, 2007 | 09:59 PM
kchungb17a's Avatar
You will not have a problem with detonation using ITR pistons on a B18C1. I am currently running this setup with a .50 mm over size with no problems. You should be able to go to 11+:1 on 91 octane with no problems. Use this for a compression ratio calculator:
http://technet.ff-squad.com/cr-calculator.htm
Your target setup is worry free.
Old Aug 8, 2007 | 06:57 PM
TruGsr1's Avatar
Default Re: Head Gasket Question (kchungb17a)
Awesome But i need to know what headgasket i should use. what is the advantage of using a thin HG. i know it bumps up ur CR but does it increase HP any?
The CR guide was helpful but are the diffrences in p73AO and p73OO???
Old Aug 8, 2007 | 07:28 PM
TruGsr1's Avatar
bump
Old Aug 8, 2007 | 08:56 PM
TruGsr1's Avatar
12:56 bump
Old Aug 8, 2007 | 09:42 PM
EARLdaSQUIRREL's Avatar
official honda whore
use oem gasket
dc4teg95
14
Sep 15, 2011 02:48 PM
kam 94' DC2
Apr 13, 2010 06:57 AM
duck22krazy
Nov 19, 2008 06:57 PM
CO_HaTcH
Apr 16, 2007 12:40 PM
