Check engine light
Old Aug 3, 2007 | 09:09 AM
210jdmgsr's Avatar
Default Check engine light
My IAB's quite working today should my check engine light be on. I also think it might be the sileniod that is malfuntioning because, they will work one day and the next they want. Or what do yall think it might be.
Old Aug 3, 2007 | 09:19 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Check engine light (210jdmgsr)
An IAB malfunction will not cause a CEL. Often times the purge fiter is clogged, which makes the IAB unable to release the vacuum when the solenoid is tripped. (Vacuum application closes the IAB at low RPM.)
The filter is located on part 6.
Old Aug 3, 2007 | 09:56 AM
210jdmgsr's Avatar
Default Re: Check engine light (Dogginator)
well i went out to my car and tryed to find the silinoid but it looked like it was under the IM am i looking in the correct spot.
Old Aug 3, 2007 | 10:55 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 210jdmgsr &raquo;</TD></TR><TR><TD CLASS="quote">well i went out to my car and tryed to find the silinoid but it looked like it was under the IM am i looking in the correct spot.</TD></TR></TABLE>
It is under there. That area is quite tight. Look on the driver's side. Trace the hose from the vacuum actuator to the solenoid.
Old Aug 3, 2007 | 11:34 AM
210jdmgsr's Avatar
what does it look like and what kinda tool should i use to check it.
Old Aug 5, 2007 | 07:31 AM
Dogginator's Avatar
Daisy... Daisy...
The filter is about 1/2" in diameter. It simply fits onto the IAB solenoid. Make sure the screen is not clogged.
QuickRexSi21
May 14, 2006 11:19 AM
egturbolsvtec
Mar 15, 2006 03:20 PM
tsdenny
12
Aug 7, 2005 10:25 AM
mahin
Honda S2000
Jan 12, 2005 10:55 AM
unKnown
Aug 25, 2004 12:33 PM
