electrical help please
Old Aug 6, 2007 | 08:11 PM
6genocide6's Avatar
Default electrical help please
i removed my dash from my car, 1990 integra gs elect. sunroof, power windows, manual locks, a/c, cruise... you all should know. but i was dumb and trimmed the under dash harness, took out the stereo wires, and all that little crap that doesn't "need" to be there, well, i also cut, what i thought was, the climate control clips, all of them, i re-attached all of them, i think, and i am getting a 6 coolant temp sensor, 10- intake air temp sensor, and 13 - atmospheric pressure sensor
anyone know how to fix that, the car's not starting, not even cranking, also, my left signal light stays on when i put the key into the ON position... i'm stumped
thanks in advance honda-tech.
Old Aug 6, 2007 | 11:34 PM
6genocide6's Avatar
Default Re: electrical help please (6genocide6)
bump, really need help if someone can.... please
Old Aug 6, 2007 | 11:50 PM
sdinteg's Avatar
All i can say is... check your wiring again. If it was working before you took the dash out, something must not have been put back correctly. The climate control wiring will not throw those codes, but the ECU wires could. Not sure what else you cut...
You might want to try resetting the ECU to clear the codes if you think it was fixed. If they re-appear shortly then you still have a problem.
Old Aug 7, 2007 | 08:58 AM
6genocide6's Avatar
Default Re: electrical help please (sdinteg)
well one thing i forgot to mention, before yesterday, on my gauge cluster, my check engine light wasn't coming on at all when i turn the key to the on position, there's a little black box that goes under the dash that is mixed in with the climate control wiring, i put that back in , and now the check engine light comes on when i turn the key for 2 seconds, then goes off. my computer is throwing those 3 codes, but my CEL is not coming on, i have experienced that before, as far as an O2 Sensor is concerned. the computer throwing a code but no CEL.
i'm going to check all the wiring, maybe i'm missing something, i do alot of wiring myself but this one is tough...
thanks
Old Aug 7, 2007 | 08:59 AM
MadVtak's Avatar
* B A N N E D *
From: Biggest Baddest Little City in The World RENO, NV
Ouch, goodluck
SkUrCh
Old Aug 7, 2007 | 09:37 AM
djtsmith007's Avatar
Default Re: (MadVtak)
The only thing you can do is go back and re-check everything. And i hope you soldered the connections back. And maybe next time...LABEL everything
Old Aug 7, 2007 | 08:37 PM
6genocide6's Avatar
Default Re: (djtsmith007)
haha... nice.. i think i got everything fixxed, i installed my new under dash harness lastnight, but i guess it was too dark so i couldn't see that i had 2 pins that were bent on the green harness plug that goes to the fuse block from the gauge cluster, i found out that i missed a wire when i re-attached everything, i put the heater and ac stuff in the car just to make sure what plugs went where, and i made sure that i re-connected everything the right way. i went to go start it. then nothing happened, i got rid of the CEL codes, and then tried again, then nothing... took out the starter on a hunch and took it to auto zone... and there the problem lays. i need a starter but that i found the problem.
Old Aug 7, 2007 | 09:29 PM
MadVtak's Avatar
* B A N N E D *
Sweet
Old Aug 7, 2007 | 09:58 PM
6genocide6's Avatar
i'm a pimp... well change the fist p to a g
i_VTEC
Feb 21, 2008 07:08 AM
Swollkat_DC5
Oct 17, 2006 04:28 PM
ace42004
Jul 7, 2004 05:49 PM
CB_ejcoupe
Apr 8, 2004 09:38 PM
Sean EH2
Jul 31, 2003 12:34 PM
