my dc2 is having some issues
Old Jan 17, 2009 | 05:14 PM
G0TB00ST's Avatar
From: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
Default my dc2 is having some issues
here is the scenario:
i was driving on the highway and i hit a bump. my exhaust piping (after the cat) started to drag on the ground. all of a sudden... my temp gauge went all the way to hot, and i pulled over and quickly shut off the car.
i waited 20 minutes and tried to start the car. NOTHING!!! my gauges light up, but no spark, no clicking, nothing! i tried a jump start, and no luck. i really dont know what to do...
any ideas?
EDIT!!!!!!!!!!!!!!!! 01-21-08
Ok... In regards to my car and the no start issue i was unclear on a couple things.
1. The fuel pump does not prime
2. The check engine light does not pop up on the dash when the key is turned on, however when i go to the crank position and go back to the on position... The oil light and check engine light comes on very very faintly!
Old Jan 17, 2009 | 05:20 PM
dc2milanoking75's Avatar
Default Re: my dc2 is having some issues
need more details what did you hit.. were on the bottom of the car got hit???? is your oil pan fine... does your car still have water in the radiator need more details???
Old Jan 17, 2009 | 10:12 PM
vietnamezerice's Avatar
did it rip any wires out? how about your O2 sensor?
Old Jan 18, 2009 | 10:49 AM
G0TB00ST's Avatar
i hit a bump on the road... m oil pan looks like its ok... it exhaust broke off after the cat...
my rad is full with coolant... nothing happened with it!
Old Jan 18, 2009 | 11:23 AM
732xghost's Avatar
hmmm boost idk. hope you figure it out. bump for you.
Old Jan 18, 2009 | 11:26 AM
HondaMotive's Avatar
Did you check if there's still oil in the engine?! Lol... Oil or coolant lost would be my guess :S
Especially with the temp gauge acting as it did.
Hope you figure it out buddy
HondaMotive
Old Jan 18, 2009 | 11:30 AM
G0TB00ST's Avatar
thanks fellas... i hope all gets fixed asap!
Old Jan 18, 2009 | 09:55 PM
DeathLens's Avatar
No leaks at all? Maybe you cracked your head?
Old Jan 18, 2009 | 10:20 PM
grey_94LS's Avatar
you said that there was no spark at all??? is the engine turning over, but just wont run???
if there is NO SPARK what soever... check the coil and ignighter... it sounds a lil wierd but , i kno in my friends b18c5, we was rippen the **** out of the car and hit this pot hole that was deep as ****, i mean the deepest pot hole i have ever seen, and the car died out, we had then figured out that the ignighter went out after sitten in the parking lot after an hour or so...but we also took apart the dizzy and found that the ignighter was loose anyways and only had one screw holding it in place, and that one was also not tight at all... we figured that the hole had enough bang to jar the ignighter and short it out...
as far as the temp going up thats wierd... unless your loosing water/oil then it shouldnt go up at all... and you said your not soo... maybe the exhaust being broke off where it is made the engine compartment hot for a min...
let us kno if you get it fixed... im wondering about the problem now... good luck...
bump bump bump.... SOMEONE HELP THIS GUY OUT....
Old Jan 19, 2009 | 06:02 AM
G0TB00ST's Avatar
thank you. someone told me that it might be the main relay...
i just got the car on the road last mnday, and i cant believe that im already having issues with it.
i do know that the car was always slow to start. i changed the battery on monday (when i got it on the road) and the battery was still slow to start. im thinking the reason why it wont start wo0uld be the starter... but the temp problem is a major issue for me. i have to see whats going on with it!!!
thanks for the idea... i will check it when i have free time this week. it is freezing and it makes you not wanna do anything!
Old Jan 19, 2009 | 07:06 AM
updhands's Avatar
So the car still doesn't start right? Does it crank at all? Crank slowly? Accessories/lights turn on?
To be basic and upfront it needs 4 things to start......spark, fuel, compression, and correct timing.
We need way more details.
Old Jan 19, 2009 | 07:21 AM
G0TB00ST's Avatar
Well when i turn the key... I get dash lights... But no crank... No spark...
I have to see what day is good to get to work on this car!
Old Jan 19, 2009 | 09:39 AM
matt da jdm junkie's Avatar
you can blow out ur ecu fuse if the o2 wire shorts on the ground give it a look
Old Jan 19, 2009 | 11:48 AM
jhammond_82's Avatar
Reject Papi
thats a hell of a bump you hit.
Old Jan 19, 2009 | 03:42 PM
G0TB00ST's Avatar
Thanks jdm junkie... Ill check it..
And yes jhammond... Big ****!
Old Jan 19, 2009 | 06:43 PM
boostedcoupe95's Avatar
am i gonna have to come to your house and fix this integra too lol
Old Jan 19, 2009 | 07:39 PM
G0TB00ST's Avatar
Yea man... Come through
Old Jan 21, 2009 | 11:17 AM
G0TB00ST's Avatar
ok i took off the starter... took it to autozone. it is fine (they tested it)
i noticed that when the key is at the on position, the cooling fan turn on... what could this indicate?
Old Jan 21, 2009 | 11:46 AM
the cooling fan shouldn't come on unless the engine is hot... check the coolant temp sensor?
Old Jan 21, 2009 | 11:54 AM
G0TB00ST's Avatar
i didnt check it. would that be a sign of why the car wont start?
Old Jan 21, 2009 | 12:06 PM
paton5g's Avatar
If the car won't crank, how do you know there's no spark?
Old Jan 21, 2009 | 12:25 PM
G0TB00ST's Avatar
im assuming that since im only getting accessoriories... and nothing else is happening besides the cooling fan turning on
Old Jan 21, 2009 | 02:35 PM
your coolant temp sensor is bypass so thats why your fans turns on without the car hot but that has nothing to do with ignition if your starter wont crank the motor and the starters fine try taking a 19 to your crank pully and turning it over... what im about to say mayb upsetting.... coolants all thier/motor overheated/good starter and batt/but the motor still wont turn over.... this can only mean one thing your motor is blown threw a rod and locked up the crank... this is the only conclusion i can make im hoping that its something else thoe... is the ground on your tranny good???
Old Jan 21, 2009 | 03:08 PM
G0TB00ST's Avatar
te car was perfectly running though... i shut the car off and then tried to start it about 3 minutes after... i highly doubt that the motor threw a rod... but hey... anythings possible!
Old Jan 21, 2009 | 06:30 PM
G0TB00ST's Avatar
mecca858
Apr 3, 2015 10:17 PM
Tegs0195
Honda Civic (2006 - 2015)
14
Feb 23, 2011 07:09 AM
ekillah
Aug 31, 2009 02:28 PM
nemeii
23
Aug 10, 2008 03:10 PM
