Starting problem
Old Jan 21, 2009 | 12:03 AM
vietnamezerice's Avatar
Default Starting problem
I have a problem starting my car... when I turn the ignition, the starter will click as if the starter has gone bad. I have replaced the contacts in the starter and cleaned it all up. My battery voltage is about 12.3-5. When I turn the ignition, I have about 11.5v at the starter signal. The starter will start right up when I jump the signal straight to the battery, I'm stumped, what can it be? Thanks for reading HT!
Old Jan 21, 2009 | 06:42 AM
fullyeclipsed's Avatar
Default Re: Starting problem
main relay is probably cooked...take it out and smell it to see if it smells burnt
btw main fuel pump relay; also could be a bad cell in the battery even if it tests ok, bad cell can cause odd behavior that you would not expect
Old Jan 21, 2009 | 09:52 AM
so the main relay doesnt only control the fuel pump? how would that link to the starter though?
Old Jan 21, 2009 | 10:29 AM
Bowman62's Avatar
does it have a solenoid? check that if it does
Old Jan 21, 2009 | 11:47 AM
on the starter? don't all starters have one? my starter starts right up when I jump it manually but not when I turn the ignition key
Old Jan 21, 2009 | 03:36 PM
you guys have any other ideas?
Old Jan 21, 2009 | 09:43 PM
late night bump for help
Old Jan 21, 2009 | 09:59 PM
untitledsn41's Avatar
Voltage seems ok, however i'd test the voltage at the battery while cranking. if it's below 10.5 volts i'd try a different battery. I'd recommend checking all ground straps just to rule that one out(hard to cary any amps over a partially connected ground.
have you tried tapping on it with a dead blow hammer while cranking it? maybe it needs some knockin around
Old Jan 21, 2009 | 10:10 PM
the battery is brand new and doesn't drop to 10.5... i added extra grounds from the battery straight to the tranny... the starter starts right up when I jump a wire from the starter signal to the (+) terminal on the starter...
Old Jan 21, 2009 | 10:17 PM
that seems bizarre. you'd think 11.5v at the signal wire would be good enough. maybe try tracing the wire and cleaning all connections with electrical cleaner and re-attaching them with dielectric grease.
Old Jan 21, 2009 | 10:23 PM
that's exactly what I've done so far... haha... man this sucks... do you think the starter signal isn't getting enough amps from the ignition switch?
cksnah252
12
Sep 9, 2014 07:51 AM
FSS13foxtrot
Apr 1, 2008 08:05 PM
honda head
Jan 28, 2007 01:35 AM
KtHaNxBai
Jan 26, 2007 09:55 AM
junya16
Feb 26, 2003 08:31 AM
