driver side headlight is very dim????
Old Jan 23, 2009 | 04:38 PM
frost_0ne's Avatar
Default driver side headlight is very dim????
well i searched and i found nothing!!!
what im driving 94 integra with a 98+ front... heres my problem is that my driver side headlight is not as bright as the passenger side and when i turn my highbeams on it shuts the whole driver side headlight off completely.. i tested the voltage right at the plug and its gettin about 8-9volts... ive changed the fuses, replaced the light bulb, checked the wiring for any broken or fraying.. i also changed out the light switch on the steering column as well.....
any ideas guys thanks in advance????
Old Jan 23, 2009 | 06:36 PM
frost_0ne's Avatar
Default Re: driver side headlight is very dim????
anyone???
Old Jan 23, 2009 | 06:43 PM
PACT man's Avatar
check the ground, make sure theres a good connection with no corrosion, if anything u mite need to take the ground off and wirebrush around to clean it up a little and reinstall.
Old Jan 24, 2009 | 07:54 AM
Dogginator's Avatar
Daisy... Daisy...
^^^ I agree.
Old Jan 24, 2009 | 08:56 AM
frost_0ne's Avatar
ill give that a try today
Old Jan 24, 2009 | 04:25 PM
StokelesS_g2's Avatar
Rewire your headlights completely.
http://www.rowand.net/Shop/Tech/Wiri...ightRelays.htm
There's more tips on this trick, just google it.
Old Jan 25, 2009 | 01:55 PM
boostedjdmdc2's Avatar
yah its prolly the ground
Old Jan 25, 2009 | 08:19 PM
superacecardriver's Avatar
sounds like you have some unwanted resistance in the headlight circuit. 8-9 volts I think it would be the source voltage like 12 to 14volts. Right? After you clean the ground for the headlights, I would break the circuit in half mentally and do resistance checks throughout the circuits path. These all being done after the obvious being check first. I wouldn't get to deep into it yet.
Veency
Lighting
Jul 14, 2016 01:46 AM
Brown-tec
Oct 29, 2006 10:48 AM
gold_ef
Oct 20, 2006 02:43 PM
Zohigh
Jan 6, 2003 06:42 AM
fiebru1119
May 9, 2002 06:03 AM
