Help revving problem!!!
Old Jan 20, 2009 | 02:51 PM
projeck_ek9's Avatar
Default Help revving problem!!!
i just recently picked up a 99 integra automagick
any who...
MY CAR TAPS OUT AT 3500 RPM
my brother has worked on many hondas and well this one is just giving him cracks..lols
behind the cluster the wires are all hacked...rpm dosnt work but it jumps up and down when the car is revving like crazy....checked the dizzy cleaned out the IACV and now were just stumped...im trying to find a obd2a to obd1 jumper harness and run a ls ecu on it...but idk...can some one help me out please
THNAKS IN ADVANCED
check engine code throwing 4 but my friend says he already changed it?
Old Jan 20, 2009 | 06:57 PM
EJ1 LS guy's Avatar
Default Re: Help revving problem!!!
I had a reving problem and I had to adjust and clean the FITV...and It fixed it......
But your toppin out at 3500....Iono....I would've said the dizzy but you said you checked that
so iono......but hope I helped......
Old Jan 20, 2009 | 07:54 PM
FITV? whats that? im sorry....
Old Jan 20, 2009 | 11:19 PM
EJ1 LS guy's Avatar
It's the Fast Idle Thermo Valve......
Try searching it.....I would give you the
link but I can't find it right now.....
Old Jan 20, 2009 | 11:21 PM
92hatch!'s Avatar
maybe it needs a tune..? that fixed mine..
Old Jan 21, 2009 | 12:01 AM
grey_94LS's Avatar
dose it sound like a 2step when you hold the pedel down the whole way to the floor???
my LS did that for a couple of days... i had a few problems..
1) the main fuel relay was shorting out and sometimes it would be fine... so i switched it.
2)the ignighter was bad in the dizzy,but it let the car start and run...
3)the O2 sensor wires pulled out of my harness
so i fixed the O2 sensor first (by putting the wires back in the clip.
then i replaced the ignighter from a single cam dizzy i had laying around
then i finally found a main fuel relay at a junk yard that was obd 1
after that my car ran perfect... you might want to try a few of these and let me kno what happens with it... good luck...
Old Jan 22, 2009 | 06:32 PM
808unknown's Avatar
im using my firends account...oh yah and my car sucks up gas like a v8 errr its erratating me....thanks for the help guys keep um commin ill probley check this out tommarow
Old Jan 22, 2009 | 06:34 PM
808unknown's Avatar
yah it sounds like a two step!!!! will do this tommarow thanks alot
ay_dawg
Sep 20, 2006 01:56 PM
TwistedSI
14
Jun 20, 2004 04:24 AM
WrongWheelDrive
Sep 18, 2003 10:43 PM
