cut eibachs
Old Jan 19, 2009 | 09:34 PM
whitehf's Avatar
Default cut eibachs
has anyone ever cut thier eibachs before? how safe is it? hows the ride? i have them eibachs on blues right now and i want my ride a 1.5 inch lower.
Old Jan 20, 2009 | 04:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: cut eibachs
It will be crap. For one thing those Tokcio HP shocks won't be able to handle it. The springs would be shorter, with a slightly higher spring rate before, but still probably not stiff enough to keep it from bottoming out.
Something like Koni Sports would be able to handle it, but it would still probably bottom out all the time.
Just get race springs on Tokico Illumina or Koni Sport shocks if you want to be lower. Don't do a half@$$ job and make your car bounce around the road like a rice-mobile.
Old Jan 20, 2009 | 07:44 AM
safedriver's Avatar
I tried the eibach springs (that drops the car 1.5" and 1.3") with blue T shocks and the car handles the bumps better, but the rear was so low that it made the front seem higher.
I put the OEM rear springs back on and now the car seems lower in the front and sits much more even.
While I was having the suspension work done, I had rear toe and camber adjustments installed. I do not have any rear camber wear.
I already, had SPC front adjustment ball joints. No camber wear up front, either.
Here is a photo of the car with front (only) eibach springs:
https://honda-tech.com/album.php?alb...pictureid=9969
Old Jan 20, 2009 | 08:36 AM
LS stretch's Avatar
just dont. save your money and buy the right springs/setup for the ride height you want
Old Jan 20, 2009 | 10:40 AM
mrdeadman's Avatar
They let me pick
Do not cut your springs. Ever.
B_Swapped93
Suspension & Brakes
Feb 14, 2013 05:29 PM
CivicHP
Suspension & Brakes
Aug 21, 2006 08:36 PM
mikeunreal2
Suspension & Brakes
Aug 8, 2006 07:25 PM
mhng
Suspension & Brakes
May 29, 2005 06:07 PM
StanBo
Jan 23, 2002 03:50 PM
