Replacing head gasket on 00 SI . WHat kind to get?
I believe my head gasket is leaking. I'm not sure if it's the head bolts that is loose or what. Anyone ever have a problem with the head bolts being loose.
I don't want to wait until it blows which may cause damage to the block/engine. Should I use the stock head gasket or COMETIC one? ITs for 00 SI JR SC at 6lb soon to be 9lb.
How much is for labor?? 500+???
THanks
[Modified by GOKOU, 4:26 PM 8/21/2002]
[Modified by GOKOU, 4:42 PM 8/21/2002]
THanks
Re: Replacing head gasket on 00 SI . WHat kind to get? (GOKOU)
Stock has always worked well for most people. For big boost applications if you go turbo I would get an Inline Head gasket to lower compression.
I've got a '99 Si and mine started leakig a week or two ago. I'll be replacing mine with a Cometic HP .057"
You can keep the intake manifold bolted to the head as you pull it out.
Re: Replacing head gasket on 00 SI . WHat kind to get? (ElectronMan)
Thanks! Do you know what size is the stock head gasket? Is the thickness .057" ? Bore size 82 mm?
Just wondering if the intake manifold will need to be taken out to get the head gasket replaced?
