What is Blowby?..
Old Aug 24, 2002 | 01:05 PM
Integra_Boi's Avatar
New User
Default What is Blowby?..
i've already done a search.. didn't find nething.. i sort of get the idea about blowby when boosting but could someone explain this once more..
Old Aug 24, 2002 | 01:13 PM
Kamin's Avatar
Default Re: What is Blowby?.. (Integra_Boi)
i belive its when both the intake and exhaust valves are open at the same time allowing air to flow through the cylinder without being mixed/combusted.
Old Aug 24, 2002 | 02:04 PM
shadowdawn's Avatar
Default Re: What is Blowby?.. (KAMiN)
I'll take a different stab and say it has something to do with oil, like a ring going and oil blowing by the combustion chamber and being burnt.... of course I could be way off I'll leave the real explanation to the experts
Old Aug 24, 2002 | 02:14 PM
TurbothisLS's Avatar
Default Re: What is Blowby?.. (shadowdawn)
shadowdawn,
is the fmu a 12:1?
also, is a fmu with an AFC enough to fuel the turbo system?
thanks
Old Aug 24, 2002 | 02:19 PM
shadowdawn's Avatar
Default Re: What is Blowby?.. (TurbothisLS)
shadowdawn,
is the fmu a 12:1?
thanks
Its a 12:1 fmu yes a fmu setup alone is ok to run 7 or less psi for a little while or a long while if you don't boost that much and rarely hit the track like me.... however I am ditching the FMU as of monday to go straight with the AFC hack as I have much more faith in bigger 440cc injectors with the AFC to trim fuel then 100+ psi of fuel pressure during boost :/
So you will see my fmu for sale very soon
Old Aug 24, 2002 | 02:25 PM
so i don't necessarily need a fmu?
i can just run an AFC with bigger injectors?
and what's a missing link?
also, what is the best to run 6:1 or 8:1 or 12:1 fmu?
Old Aug 24, 2002 | 04:01 PM
BigMoose's Avatar
Hi Hotang,
Blow by is typically seen in a worn engine. It is the combustion chamber gasses blowing by the rings and entering the crankcase. It usually is precipitated under stock conditions by many miles (150,000+) or not enough oil changes.
Blow by adds heat to the crankcase, accelerating oil oxidation, acid formation and aging. Blowby is seen in the PCV system with a lot of oil ingested into the intake breather.
It is also brought on by detonation in boosed engines. Under these conditions the ring lands start to collapse and other nasties happen.
If an engine is susceptible to detonation blow by aggrevates the situation as ingested oil like to aid detonation. Nice little run away situation.........
It can also be seen on a very new engine untill the rings seat.
Hope this helps some.
Regards,
BigMoose
edit to fix by darn inability to spell
[Modified by BigMoose, 8:03 PM 8/24/2002]
Old Aug 24, 2002 | 04:22 PM
sutrusu's Avatar
dude, 12-1 and you do need an FMU!!!
Old Aug 24, 2002 | 04:30 PM
shadowdawn's Avatar
Default Re: What is Blowby?.. (sutrusu)
You don't need a FMU with 440cc's and a AFC setup, If you use a 12:1 fmu AND the afc hack you are a moron. FMu simply isen't needed up to 10psi with the afc hack setup.
Old Aug 24, 2002 | 08:23 PM
rjardy's Avatar
THE HACK is so you dont have to use a boost dependent regulator (FMU)
Rob
Old Aug 24, 2002 | 08:50 PM
Ri5e's Avatar
Default Re: What is Blowby?.. (rjardy)
Blow by is when exhaust gases go pass the piston rings. Piston rings aren't 100% sealed so gasses can go by them and get into the crank case. If you have blown ring lands you'll get a lot of blow by.
Old Aug 24, 2002 | 09:04 PM
New User
Default Re: What is Blowby?.. (BigMoose)
thanks guys, i get a general idea i guess.. even though i heard a few different answers... btw.. who are u bigmoose?
Old Aug 24, 2002 | 09:53 PM
PrecisionH23a's Avatar
Hi Hotang,
Regards,
BigMoose
listen to him, he summed it all up so i dont have to
Old Aug 24, 2002 | 11:16 PM
i still don't understand the terminology.
what is an AFC hack? I have an AFC and it is installed. What makes this setup a hack and others just have an AFC?
thanks
Joe
Old Aug 24, 2002 | 11:20 PM
shadowdawn's Avatar
https://honda-tech.com/zerothread?id=137901
Search function..... use it, it saves motors
[Modified by shadowdawn, 3:20 AM 8/25/2002]
97grnrs
Dec 4, 2006 03:26 PM
redlseg
Apr 28, 2005 05:39 PM
JforJonathan
Apr 6, 2005 10:25 AM
kovert
Aug 17, 2004 09:58 AM
RTW DC2R
Jun 5, 2002 07:41 AM
