apexi BB turbo
Guest
Posts: n/a
is anyone else using a APex'i BB turbo kit on a 96+ SOHC civic motor? What are the fitment and wire issues if any, and how does the Apexi unit manage itself? Does it use a "black box" like the GReddy unit? I also have a OBD1 ECU conversion if that makes a difference.
uses fmu, intank fuel pump and missing link. i'd suggest getting a hondata since you already converted to a odb-i computer or you could go a little cheaper with the v-afc hack.
there are no fitment issues though, except for the fact you have an extra air temp sensor compared to 92-95 civics. you need to tap into your intake pipe and jus plug the sucker in there. other than that you're good to go.
