how do i clock my turbo when its all rusted?
i getting my setup all ready and the turbo i got is kinda rusted together on the exh. housing part. i can clock the comp. part easy but the iron stuff is rusted on. how did some of you guys clock your rusted stuff. its a t3 off a svo
Re: how do i clock my turbo when its all rusted? (batboyvaj)
Spray Wd-40 ont he bolts and try to use a big wrench. If that doesn't work, heat up the turbo with a torch and try again. After the bolts are loosened, try rotating it. If it doesn't rotate, spray Wd-40 and use a rubber mallet and bang on it. Eventually it'll break loose.
